NooTheme Premium WordPress Theme › Forums › JobMonster › Most important features NOT WORKING
- This topic has 15 replies, 4 voices, and was last updated 6 years, 4 months ago by
6 years, 4 months ago #1080871
Hi super team,
I'm having a big bug in the website right at this moment, the major function it's not working.
I've made the update to the latest version of worpdress 2 days ago. But I've only noticed today (an employee informed me) that somethings were not working correctly. The update is made manually because of the security measures implemented in this company. After that two things happening:
- At this moment nobody is able to approve or disapprove applications. We are able to press the buttons, the confirmation popup opens up, but after confirming nothing happens. The application status stays the same.
- Another thing is, in the applications when we try to open almost every resumes, it says that we're not able to see them because they are private.
Please, I beg for urgency on this one.
6 years, 4 months ago #1080872This reply has been marked as private.6 years, 4 months ago #1080873I've forgot to say that I already updated theme aswell.
6 years, 4 months ago #1080874I've noticed also that since theme update, when someone is filling a resume, in the bottom an openable bar appeared with the text "collapse1".
6 years, 4 months ago #1080889
Posts: 155Hi,
Please send me an FTP account. I will check it for you.
6 years, 4 months ago #1080916This reply has been marked as private.6 years, 4 months ago #1080925Hi there,
well, but to the existing companies and jobs, approving function it's not working.
I reject application
Next I confirm
Delivering this message "No application rejected"
And the application does not get rejected, stays the same:
This is that bar in filling resume (COLLAPSE1)
Another thing appeared in jobs descriptions. When a candidate opens a job, beneath the "apply" button there's this:
6 years, 4 months ago #1080927<Please ignore about the private resumes issue. Was not an issue.>
6 years, 4 months ago #1080929Hi,
You can create a company account and reproduce the above problem.
Later send me the account info. I will help you check.
6 years, 4 months ago #1080934This reply has been marked as private.6 years, 4 months ago #1080938With the admin account that I've sent you, I can create jobs and works normally. If it's not admin it doesn't work.
6 years, 4 months ago #1080964Hi,
The reject job issue has been solved.
6 years, 4 months ago #1081053Hi team,
the reject/approve button issue it's solved, but now the same problem goes to the delete button in the application actions.
6 years, 4 months ago #1081074Hi,
Did you create a job from the backend instead of the frontend?
If you create the job following these steps, I think no error will occur:
- Register an employer account -> Login
- Post a job with this account
- Register a candidate account -> Login -> Apply to the above job
- You go to employer dashboard -> Manage Application -> Delete the application.
I will wait for a response from you.
6 years, 4 months ago #1081092Well, it worked. Don't know what I did yesterday. Thanks mate
6 years, 4 months ago #1081164
Posts: 87Hi again,
We are very happy to help you.
