NooTheme Premium WordPress Theme › Forums › JobMonster › Member login – employer and job seeker
- This topic has 5 replies, 2 voices, and was last updated 6 years, 2 months ago by
6 years, 2 months ago #1082334
I tried to edit the employer page and job seeker page. They should be separate pages. Employer is allowed to post jobs whereas job seeker will be able to upload resume once they have registered and log in.
When I am logged in and trying to edit these pages which I found as "Member" page, many pages are empty. Once I clicked "Member" page trying to edit, it shows the page directly on the front end which doesn't allow me to edit anything not even the url. Kindly assist and explain how do I go about with this.
https://www.jobsykey.com/mock/member-2/manage-job/
6 years, 2 months ago #1082349Hi,
You can create a new page and use the shortcode [noo_member_account]. You can create a new page and use the shortcode [noo_member_account]. After finishing editing, go to Jobmonster -> Settings -> Member tab -> Member Manage Page -> select the page you have just created.
Note: After you save the settings you will not be able to customize this page. If you want to customize, you will have to uncheck the "Member Manage Page" option
6 years, 2 months ago #1082668Why does so many of my pages layout run off? this is just few samples I've attached. Many more pages are the same like this. Did I import the pages incorrectly?
6 years, 2 months ago #1082669How do I add the packages to this section in attachment?
6 years, 2 months ago #1082673I have created Employers and Job Seekers pages(in menu) with shortcode [noo_member_account] https://www.jobsykey.com/mock
However, the pages are unable to be click from the menu, it doesnt redirect to the page with login.
In pages, I have already created another page "Member" with [noo_member_account] .
Is there a conflict if I use it [noo_member_account] shortcode more than once?
6 years, 2 months ago #1082712Hi,
- Package: You go to Product and create new Job Package. You currently have no packages.
- You can only create 1 page with shortcode [noo_member_account]. This page has only one task to manage account of the Candidate or Employer user -> Display queries from the member menu. . http://prntscr.com/qic91p
Note: It only works when assigned to the Member page: http://prntscr.com/qica6m
