NooTheme Premium WordPress Theme › Forums › JobMonster › Manage Application Without User i need help regarding this
- This topic has 21 replies, 3 voices, and was last updated 7 years ago by
prathap.
7 years, 2 months ago #1067348
i need help regarding this like how to use it and how to register or sign in or create account or how it works
how to use or how to work with it or for which propose
it is asking Company ID and Secret Key
i cannot even create account for this or i dont know where is this to create
thanks
7 years, 2 months ago #1067422This reply has been marked as private.7 years, 2 months ago #1067430Hi again.
Sorry for the mistake.
Please go to the Dashboard Jobs/ Companies and edit the company you want to use that feature. You will see the company secret key option on the right sidebar.
7 years, 2 months ago #1067463This reply has been marked as private.7 years, 2 months ago #1067521This feature used for the company - who don't have register user on your site, but still have the job posting adding by admin.
The admin assigns the job to this company. And the company can manage the application by using the link, secret key when they want.
7 years, 2 months ago #1067576This reply has been marked as private.7 years, 2 months ago #1067895waiting for reply
so that i will close this topic
7 years ago #1070739This reply has been marked as private.7 years ago #1070773Hi again.
You can enable the WPBackery page builder for the Company post type, then you can add the notice to the company description.
To enable the WPBackery page build for the custom post type, please go to WPBackery Page Builder/ Role manager/ select custom for Post types and check to noo_company.
7 years ago #1070842This reply has been marked as private.7 years ago #1070851This reply has been marked as private.7 years ago #1070878
Posts: 3295This reply has been marked as private.7 years ago #1070886This reply has been marked as private.7 years ago #1070900
Posts: 3295This reply has been marked as private.7 years ago #1070913This reply has been marked as private.7 years ago #1070936
1- We understood your question. Please see this image: https://prnt.sc/n192gw
2- Currently, you can go to JM Jobmonster > Custom Fields > Application then add more fields for the application form. You should check it, then feedback us.
7 years ago #1070955This reply has been marked as private.7 years ago #1070977
Thanks for getting back to us
1- Please try to use Visual composer shortcode then add a shortcode to make your desired.
2- Currently, we don't have any options to help you edit or add more fields in an application. In case, please describe your question as clearly as possible and give us some image descriptions, then we will try to discuss with our developer who can help you with an extra fee.
7 years ago #1070990This reply has been marked as private.7 years ago #1071031
1- Please give us your contact form page and the subject which you want to add clarity. We will try to help you add it on your website.
2- For example, we added the Subject option to the Application form. You can see this image: https://prnt.sc/n2fkda
and the attached image.
7 years ago #1071052This reply has been marked as private.7 years ago #1071707This reply has been marked as private. -
