NooTheme Premium WordPress Theme › Forums › JobMonster › Maichimp issue
- This topic has 7 replies, 2 voices, and was last updated 3 years, 9 months ago by dangdv.
3 years, 10 months ago #1204480
Eventhough my Mailchimp API is correct and linked in the Widget appears the following message:
"There's a problem getting your mail list, please check your API key at MailChimp Settings in Customizer"
And also when I try to subscribe the following error appears:
"There is an unknown problem. Please reload and try again."
The link to my page: http://www.jobtiger.ch (Mailchimp in Footer)
3 years, 10 months ago #1204529You have add Mailchimp API on your site ? Please go to 'Customizer -> Site Enhancement' to add Mailchimp API then check your site again.
3 years, 10 months ago #1204547Hi
of course I have: https://prnt.sc/t8j8gh
3 years, 10 months ago #1204610Dear, After add Mailchimp API key, you need go to edit mailchimp widget in footer and select a list in setting 'Subscribe Mail List'. After select a list to for widget, if it stil not work, please kindly send for me admin account your site via private reply .I will check details problem on your site to help you.
3 years, 9 months ago #1204768This reply has been marked as private.3 years, 9 months ago #1204796Dear, i have check again i see the Noo Mailchimp widget can't load Mailchimp list when not install Mailchimp for WordPress plugin I will fix it in next update version.
To fix your problem, i have install Mailchimp for WordPress plugin on your site, Now, please go to check your site and select mailchimp list for Noo Mailchim widget.
3 years, 9 months ago #1204853hi
did as you suggested. The Mailchimp list can now be selected in the Noo Widget, but when I try to subscribe, still the same error.
Could you pls have a look again?
3 years, 9 months ago #1204864That problem because you not select and update Mailchimp widget, i have select mailchimp list and now i see it's working, please check your site again.
