Tku! I finally could access to support.
I have had for quite a long time on my site mikalos.com the following error showing, at first I contacted the hosting to find out if that was related to them, they looked into it, and it was not their issue; therefore I need you.
Error: cURL error 28: Operation timed out after 10001 milliseconds with 0 bytes received (http_request_failed)
Also, there is this other problem:
It was not possible to confirm filter wp_version_check()
which stops background updates happening.
Looking forward to your answer,
Liz Gámez
