NooTheme Premium WordPress Theme › Forums › JobMonster › Login Error
- This topic has 18 replies, 3 voices, and was last updated 7 years ago by
7 years ago #1069077
When the users login and as they move to the previous page they were on, they will have to refresh again in order to proceed as a logged in user. Is there any way to rectify this ?
Thank You
URL -> https://www.me-jobhunters.com
7 years ago #1069169
Posts: 3295Hi.
We are so sorry for late response because we had a weekend so we cannot help you during that time.
For your question:
Currently, when a user got access to Jobmonster's website, it will be redirected to a page which he/she has stayed on before. In addition, you absolutely configure a page which a user will redirect by going to JM Jobmonster > Settings > Member > Redirect to Page after login.
7 years ago #1069194Hello,
I am sorry, but after login the user is not redirected to the page they stayed on before. Is there any way to make it that way ??
7 years ago #1069280
Please make sure that you have used the latest version of Jobmonster theme. In addition, you had better give us your information again. We will check this logic.
7 years ago #1069356This reply has been marked as private.7 years ago #1069442
We have got access to your website then found that you have used the older version of Jobmonster theme. The latest version is 4.5.2.2
Please update our theme to get this feature on your website.
7 years ago #1069443This reply has been marked as private.7 years ago #1069444This reply has been marked as private.7 years ago #1069445This reply has been marked as private.7 years ago #1069478
There 2 ways which help you to update our theme without losing your customization.
First, you should back-up all customization files before updating. That's mean, you should copy them to a folder of your company.
Second, you should install ChildTheme then write all your customization files in here. It will be kept when updating our theme.
In addition, if you don't see a notification about updating our theme, you had better update it by manual way. Go to ThemeForest market then download the newest version of Jobmonster. After that, upload it via FTP or WordPress.
7 years ago #1069584Hello,
Well I did update and now when we login the landing page works. But after registering it is not the same ? Is there any way to make the candidates be on the same page they were before registering ?
7 years ago #1069669
We only support to redirect the same page after getting access to Jobmonster's page. Register an account isn't the same. Because for an employer, after registering, it will redirect to the company profile.
7 years ago #1070219This reply has been marked as private.7 years ago #1070358Hello, any solutions to the above problem ??
7 years ago #1070377
Posts: 3295This reply has been marked as private.7 years ago #1070387Attaching the coverage server error...
7 years ago #1070452Hi.
With the Google server error, you should create a robots.txt file and block the access to wp-content folder.
https://support.google.com/webmasters/answer/6062596?hl=en
It's not a real problem, follow the article to know more about that https://productforums.google.com/forum/#!topic/webmasters/Tu2QfLiMn_8
Thank.
7 years ago #1070465This reply has been marked as private.7 years ago #1070484As this topic https://productforums.google.com/forum/#!topic/webmasters/Tu2QfLiMn_8
it's not a real problem. You can ignore the message. Or you can use the robots.txt to block the PHP file.
