NooTheme Premium WordPress Theme › Forums › JobMonster › Linkedin Login not working
- This topic has 16 replies, 2 voices, and was last updated 6 years, 11 months ago by
6 years, 11 months ago #1071713
Hello I have configured linkedin as per document, however when I click on login, I get error like attached as below.
I had done configurations as suggested like Key/Secret. If you need I can give you site access with admin.
6 years, 11 months ago #1071740
Please fetch in your LinkedIn configuration. You can see the attached image.
Rember to fetch your website with an exact structure. For example
Redirect URLs: http://wp.nootheme.com/jobmonster/
6 years, 11 months ago #10717556 years, 11 months ago #1071761
You are missing "/" at the end of the website link. Please check it again.
6 years, 11 months ago #1071764Hello After doing that LinkedIn is allowing login ( Redirected to Linkedin, logged in sucess, allowed to view details ) but after that it redirected to the site (jobsdata.in) but it stil show Login button and not showing customer as logged in one. And no error is getting displayed.
6 years, 11 months ago #1071808
Can you provide us with your website's URL & admin account and FTP account privately via checking Set as private reply checkbox. We will get access to your website and check this issue.
6 years, 11 months ago #1071829This reply has been marked as private.6 years, 11 months ago #1071853
Can you provide us your FTP account also? Because we need to get access to your source code and see the issue.
6 years, 11 months ago #1071856This reply has been marked as private.6 years, 11 months ago #1071859
What's about your hostname?
We have used FileZilla tool to get access to your FTP.
6 years, 11 months ago #1071860
6 years, 11 months ago #1071861This reply has been marked as private.6 years, 11 months ago #1071893
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1071947This reply has been marked as private.6 years, 11 months ago #1071950
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1071959This reply has been marked as private.6 years, 11 months ago #1072035
The issue is your LinkedIn API key. We also added our LinkedIn API key to your website then check the login issue, it still works fine. Please see the attached image.
In addition, you can refer to this topic for more details: https://nootheme.com/forums/topic/linkedin-login-not-working-2/#post-1072032
