NooTheme Premium WordPress Theme › Forums › Timetable › Level filter not working correctly.
- This topic has 9 replies, 2 voices, and was last updated 3 years, 6 months ago by
7 years, 1 month ago #1068860
We have successfully setup the NooTimetable plugin, but having some issues with the filters.
On this page, the 'Show Filter' option is set to "No", but is still showing:
https://flametreeyogastudio.com.au/beginner-timetable/On this page, the filter is displaying correctly, but clicking any of the filter options does not have any effect:
https://flametreeyogastudio.com.au/yoga-class-and-timetable/Any advice on how to get the filters working properly would be much appreciated, thank you.
7 years, 1 month ago #1068861This reply has been marked as private.7 years, 1 month ago #1068882Hi,
I checked the above issue. I added some lines for NooTimetable plugin.
7 years, 1 month ago #1068886Thank you for the update, and very quick support response, everything is working well.
Was this a code update? If I update the plugin in the future will it break the fix you have implemented?
7 years, 1 month ago #1068887Hi,
You don't worry this issue. I will update in the next version.
7 years, 1 month ago #1069116You don't worry this issue. I will update in the next version.
When I update to the latest version of the plugin (2.0.5.3) the filters break again. With v2.0.5.3, we just get a message saying "No Events Found".
I've had to revert to a backup and restore v2.0.5.2 and whatever changes you implemented for us on https://flametreeyogastudio.com.au/yoga-class-and-timetable/
7 years, 1 month ago #1069124Hi, as well as my earlier email (#1069116) about v2.0.5.3 breaking the filters, we've noticed that when the toolbar is turned on and the user clicks 'next' or 'previous' the timetable displays a message "No Events to Display". However the classes are configured to display for the next 100weeks.
You can see this happening on the following page here:
https://flametreeyogastudio.com.au/yoga-class-and-timetable/The WordPress login that we previously provided to you is still valid.
7 years, 1 month ago #1069188Currently, you should still use version 2.0.5.2 and wait the version 2.0.5.4.
3 years, 7 months ago #1219256To me the filters of the classes do not work either. I need to create a different time for two pages and the only way to exclude classes from one page to another is to use filters. But the filters don't work, because they don't show me the classes I choose. Can I be helped?
3 years, 6 months ago #1219287Thank you for contacting us.
Sorry, do you mean the filter on the schedule? On our site, it still works fine. Please give us your site URL and admin account, and we will help you check it soon.
