NooTheme Premium WordPress Theme › Forums › Jobica › jobs page not displaying anthing – blank
- This topic has 14 replies, 2 voices, and was last updated 5 years, 11 months ago by
watsond1920.
5 years, 12 months ago #1092175
Hi ..
I have been working on getting my site up and running using the jobica theme, but I ran into a small problem. Under the Jobs->Jobs menu I now get a totally blank page.
It used to work properly and then I started to populate the company records using the Plugin All Imports to import my database of company (~350K company's) into the site.
After that, the Job display no longer seems to work - all the other menus seem to work correctly, but most important one: Jobs->Jobs does not.
Can you please help me determine what has gone wrong in the jobica theme
Thanks for you help
5 years, 11 months ago #1092456Dear, please kindly send for me admin account and your site URL via private reply,i will check details problem on your site to help you.
5 years, 11 months ago #1092887This reply has been marked as private.5 years, 11 months ago #1093758Dear, i have check your site and check Job listing in admin menu but it's give blank page, now please:
1. Backup your site code and database.
2. Update WordPress and all plugin on your site to latest version
3. Enable DEBUG mode on your site, i need see what is error message on your site.After do steps. please tell for me, i will check your site again.
5 years, 11 months ago #1093774This reply has been marked as private.5 years, 11 months ago #1094270This reply has been marked as private.5 years, 11 months ago #1095972This reply has been marked as private.5 years, 11 months ago #1095979This reply has been marked as private.5 years, 11 months ago #1096073I don't sure that problem in post_meta table. You can send for me FTP account on your site, i will check log error to help you fix it.
5 years, 11 months ago #1096386This reply has been marked as private.5 years, 11 months ago #1096430This reply has been marked as private.5 years, 11 months ago #1096959This reply has been marked as private.5 years, 11 months ago #1096962This reply has been marked as private.5 years, 11 months ago #1097365Dear, please compress file error login with Zip file and send for me again.
5 years, 11 months ago #1101681Hi Dang ..
My senior partner has decided that since the site has been configured now properly, that we will deploy it to its final domain name so that we start getting usage on the site.
I thought that it was better to purge the useless company data, so I am currently purging all the company data so that the job functions will work correctly for a small user base and community which is probably what this applicat designed.
Wordpress in general, can't handle a large data sets, so we will have to design/use something else to allow the posting of a large database of Jobs.
Thanks for all your help
Dave W.
