NooTheme Premium WordPress Theme › Forums › JobMonster › Jobs not publishing
- This topic has 7 replies, 2 voices, and was last updated 5 years, 10 months ago by
5 years, 10 months ago #1136908
When an employer adds a new job it does not publish the job and stays as a draft.
In the JobMonster settings we have "Job Approval" NOT ticked (see image) so that Admin doesn’t have to approve them. It was working OK a few weeks ago but now it has stopped.
Do you know how we can fix it so that the employers can post jobs without approval?
Many Thanks
Regards
Colin5 years, 10 months ago #1137574Dear, if you work on few weeks ago and now it's working, you have install and use new plugin cause conflict ? Please check again or if send for me admin account your site and your site URL via private reply, i will check details to help you.
5 years, 10 months ago #1137623Hi
The only thing that has been updated from a few weeks ago is an update of JobMonster to the latest version. No other plug-ins have been installedMany ThanksRegardsColin5 years, 10 months ago #1140690I have check Jobmonster theme again. I see post job still working, Your problem happening will all Employer account or with some Employer ? please kindly send for me admin account your site and your problem URL via private reply I will check details to help you.
5 years, 10 months ago #1140694This reply has been marked as private.5 years, 10 months ago #1141141I have login to your site and check post job, i see it's publish. I think that problem in Jobmonster theme when WooCommerce plugin not activate. I have activate WooCommerce plugin on your site and it's working, please check your site again.
We're will check problem in theme with WooCommerce plugin to fix it in next update version.
best regards.
5 years, 10 months ago #1141144Hi
That is very odd because the site was working without Woocommerce being installed, I only installed it because the jobs stopped posting. It still didn’t work when i installed it so i turned it off. Maybe by turning it on again it made it work. I don't really need Woocommerce as the site will not be taking money.
Thanks for looking into it for me.
Many Thanks
Regards
Colin5 years, 10 months ago #1143296Yes, we're will check theme when not activate WooCommerce plugin and release new version to fix it.
