NooTheme Premium WordPress Theme › Forums › JobMonster › Jobs function removal
- This topic has 8 replies, 2 voices, and was last updated 4 years, 6 months ago by hoannt@vietbrain.
4 years, 6 months ago #1085956
Hello, I know JobMonster is strongly related to publishing jobs, but my client asks me to get rid of the chance to publish job offerings.
After a new Employer user registers, is prompted with this page: how can I remove (or replace) the content? I need to get rid of the button "Post Job" for sure, but also the table row and the multiple selection menu. Can you tell me where is the HTML or PHP code?
4 years, 6 months ago #1085957Here's a picture of the page I'm talking about.
You must be logged in to view attached files.4 years, 6 months ago #1085981Hi,
You mean you want to remove the entire area that you circle in the image ?
4 years, 6 months ago #1086020Yes, I need to completely avoid that Employers post a job. Only Candidates should be able to create resumes.
I would like to replace that area with some custom text.
4 years, 6 months ago #1086077Hi,
You just need to add css line below to make it invisible:
.employer-manage {
display: none !important;
4 years, 6 months ago #1086162In which CSS file should I add it? I'm working with a child theme...
4 years, 6 months ago #1086166I have added css to your custom code for you https://prnt.sc/rfprjp
4 years, 6 months ago #1086167Thank you very much! This code is not going to be deleted on the next update, isn't it?
4 years, 6 months ago #1086169Hi,
that's right
