Dear, the default Jobmonster not support display view count on admin panel. If you want display it on admin Job list, Please install and switch your site to use Jobmonster Child Theme. Then add custom PHP code to file functions.php of Jobmonster Child Theme.
add_filter( 'manage_edit-noo_job_columns', function($columns){
$columns['view_count'] = __('View Count','noo');
return $columns;
},100);
add_filter('manage_noo_job_posts_custom_column', function($column){
global $post;
if($column === 'view_count'){
echo noo_get_post_views($post->ID);
add_filter('manage_edit-noo_job_sortable_columns', function($columns){
$columns['view_count'] = 'view_count';
return $columns;
add_action( 'pre_get_posts',function($query){
if(!is_admin()){
return;
$orderby = $query->get( 'orderby');
if( 'view_count' === $orderby ) {
$query->set('meta_key','_noo_views_count');
$query->set('orderby','meta_value_num');
