NooTheme Premium WordPress Theme › Forums › JobMonster › Job Page Contains Too Much Text
- This topic has 16 replies, 2 voices, and was last updated 5 years, 6 months ago by
5 years, 7 months ago #1206860
Good morning (0820am GMT),
I hope this message reaches you well.
I am trying to use the JobMonster Theme which I think is a fairly decent theme. I've not much experience in the past of customising themes, however I thought I would learn a new skill along the way. I am having some difficulties with the layout of some of the functionality and I cannot work out exactly why there is no option to change.
See image below:
The Image upload function only allows 2 images to be added, so I'm adding them within the text body with the image insert function.
How can this be resolved and fixed?
Do I need to update the theme or change any settings?
I've configured a few WordPress sites in the past, however not had this issue.
I hope you can help.
Thank you and kind regards,
Richard...
5 years, 7 months ago #1206863Just to add...
I did a wordcount of the text on the LOREM IPSUM text and it seems to be approximately 60 words that are generated from the Job Description section.
"Job Description Curabitur non nulla sit amet nisl tempus convallis quis ac lectus. Mauris blandit aliquet elit, eget tincidunt nibh pulvinar a. Praesent sapien massa, convallis a pellentesque nec, egestas non nisi. Curabitur aliquet quam id dui posuere blandit. Nulla porttitor accumsan tincidunt. Donec rutrum congue leo eget malesuada. Pellentesque in ipsum id orci porta dapibus. Donec sollicitudin molestie malesuada."
5 years, 7 months ago #1206865I realised the images from the text body do not show up, so I am attaching them below:
5 years, 7 months ago #1206901Dear.
1. "The Image upload function only allows 2 images to be added, so I'm adding them within the text body with the image insert function"
- I don't what is image field, please kindly give for me more details with screenshot.2. "I've configured a few WordPress sites in the past, however not had this issue."
- What is your problem ?3. "I realised the images from the text body do not show up, so I am attaching them below:"
- What is image you want tell ?Please kindly give for me more details. i will check to help you.
best regards.
5 years, 7 months ago #1206910Good afternoon,
Thank you for your response.
1. Please scroll up and see above images:
Job-Description-Word-Count.pngThe JOBS page seems to display the name of the job along with the job description within a very small field and thus you cannot see the name of the JOB and looks very untidy.
2. The problem is mentioned in full above, along with screenshots.
3. Please see images above.
Richard
5 years, 7 months ago #1206944Dear. Because all column can't display on screen, that is the reason why WordPress create screen options to disable column you don't want show. Please disable columns you don't want show to display Job Title.
5 years, 7 months ago #1207006Thank you for response,
Where do I find the functionality to disable the Job Description function in the admin view?
I wish to see the name of the job, but not see the entire support text as this is the key cause of the issue and there does not seem to be an option for such.
Please advise,
Rich
5 years, 7 months ago #1207011When minimising the screen, it would seem that all columns are set to a standard percentage width.
The Job Column should have the name of the job listed, however should not also contain the DESCRIPTION.
I have attached an image of the EXTENDED view that shows the problem.
Please can you advise?
5 years, 7 months ago #1207072This reply has been marked as private.5 years, 7 months ago #1207080Good morning (0800 GMT)
I've just checked and had no response to the above and it does not seem to have been fixed
Is there any chance of getting an update on the issue at all?
Kind regards,
Rick
5 years, 7 months ago #1207083I disable (un-check) Application and Date on screen options. Please see attachment.
5 years, 7 months ago #1207090Good morning (0950GMT)
I feel there has been some confusion.
I see your above image has worked for you, however it has not worked for me.
I have repeated the same steps and removing the two fields is somewhat irrelevant:
> The Application Field - List number of applications, thus should be viewed
> Date - Shows the date the job was published, so also relevant
What I have a problem with is that the JOB NAME field and the JOB DESCIPTION field are both merged and showing within the main jobs page.
Please see below files.
I hope this can be resolved, as in an hour or so, your support team will not return until tomorrow and ideally I would have liked this resolved today.
Kind regards,
Rich
5 years, 7 months ago #1207113I don't understand why i not see Job Descrption in admin jobs list (see attachment) How to show job description ?
5 years, 7 months ago #1207115I am unsure as to why I am seeing this.
I have tested in both EXTENDED and COMPACT view.
In accordance with your advice, I have taken the applications off and the date and it seems to resolve in the COMPACT view, however in the extended view, I am still seeing the job description.
This does solve the problem for now, however if possible, could this be looked into further tomorrow?
Thank you and kind regards once again,
Rick
5 years, 7 months ago #1207118In image attachment of reply #1207083 I use EXTENDED but not see desc job in list, i don't understand why it show with you. You can login with account you send for me and check again.
See you again.
5 years, 7 months ago #1207165I will use as it is for now, however if possible, if you could later on look into the back-end and coding as I think there may be an ongoing issue which is causing the data to be pulled. The above solution is a quick-fix, however does not fundamentally fix the inherent issue.
I will have to revoke access for now as there will be sensitive data on the site and thus will be unable to grant access otherwise.
Please advise of what to do in such instance and how to obtain support without compromising sensitive user data.
Kind regads,
Rick
5 years, 6 months ago #1207188This reply has been marked as private. -
