NooTheme Premium WordPress Theme › Forums › JobMonster › Job Map is not showing job posts
- This topic has 18 replies, 7 voices, and was last updated 5 years, 7 months ago by
Gunther.
7 years, 1 month ago #1069406
Dear support,
I have created a Job Map to enable visitors to select job posts from a graphical map. You can find this map at https://www.werkenbijeengoeddoel.nl/vacature-kaart/. As you can see there are enough job posts that should show up on the map, but unfortunately they don't. Can you please help me to fix this?
Thank you in advance!
Kind regards,
Martijn
7 years, 1 month ago #1069436
Please make sure that:
1- You have added a premium Google API for map
2. Your job address has a full and exact job's address. In addition, this address needs to exist on Map.
7 years, 1 month ago #1069464Dear Tracy,
Thank you for your reply. I can confirm that I used a premium Google Maps API I requested according to to instructions on the Settings / Locations page. This API key also works for the location of the company. Besides that I can confirm that at least one company and one active vacancy have an address that exists in Maps.
Hope hearing from you soon.
Cheers,
Martijn
7 years, 1 month ago #1069486
We tried to get access to your admin account but unsuccessfully.
Please check it again, then give us your website's URL & admin account and FTP account privately. After that, our developer will have access to your website then check it.
7 years, 1 month ago #1069522This reply has been marked as private.7 years ago #1069895This reply has been marked as private.7 years ago #1069967Hi again.
Can you check the FTP account permission again? We can't change the source code via that account?
We need to use the FTP account to debug the issue.
7 years ago #1070017Hi Jackie,
Can you please try again? It should work now.
Kind regards,
Martijn
7 years ago #1070081Hi again.
We have checked and fixed the issue on your site.
Now the job can display on the map shortcode.
7 years ago #1070391This reply has been marked as private.7 years ago #1070456Yes, we have checked and fixed that issue. Please check it again.
And don't forget to back up this file /wp-content/themes/noo-jobmonster/framework/job/job_location.php
It will help you avoid the issue on the next update.
6 years, 6 months ago #1079478I have the same problem. The map does not update on new jobs. Although I deleted the cache.
Can anyone help? Thanks!
6 years, 6 months ago #1079487
Posts: 87Hi,
Please provide us with your website's URL, admin account and FTP account privately via checking Set as privately reply checkbox. After that, we will check your issue.
6 years, 6 months ago #1079543Hi, @mynoxin.
Currently, I disabled the function optimize JS from Autoptimize plugin.
You can use plugin W3 Total Cache instead of Autoptimize .
6 years, 6 months ago #1079613I did, but the companies (Darmstadt) are not shown in the map.
6 years, 6 months ago #1079620it works now. It seems, that it takes some time to refresh the map by google?!
So: I`m satisfied now 😉 Thanks for that nice support!6 years, 6 months ago #1079635
Posts: 87Hi again,
We are very happy to help you. If you have questions, don't hesitate to ask us. We are ready to help you.
And could you please give us a 5-star rating if you feel happy with our product and customer support service. It is more important for us so it will give us more motivation and confidence to serve you better.
Here is our product link: https://themeforest.net/item/jobmonster-job-board-wordpress-theme/10965446?s_rank=14
Thank you very much.
5 years, 7 months ago #1207298Hi support,
same problem on my site:
I upgraded just some days ago from JobMonster 4.4.1 to 4.6.1 and entered the location into the new field "_full_address" with map picker of all existing jobs. All existing jobs was recorded in previous version of JobMonster 4.4.1.
But jobs will not show up on map.
Now after long time trying to find out, whats the problem, I guess that I found the reason:
I have to delete the "old" adress field for letting the jobs show up on map. As long there are old adress data together with the new data from map picker, posts will not be shown on map.Just for someone who has same problem 😉
Kind regards, Gunther
5 years, 7 months ago #1207299Hi,
sorry - but problem not solved that way 🙁
Most of jobs will not be displayed on map!
Please see job search here for all jobs have the new longitude and latitude data:
https://www.bildungsserver.net/?s=&post_type=noo_jobAns see my map only show about 5 jobs out of over 300:
https://www.bildungsserver.net/landkarten-suche-bildungsangebote-ausbildung-fortbildung-weiterbildung/Please check and find out whats going on here!!!
