NooTheme Premium WordPress Theme › Forums › JobMonster › Job Location is missing on Single Job page
- This topic has 16 replies, 3 voices, and was last updated 6 years, 10 months ago by
6 years, 11 months ago #1073465
Dear Sir,
Job location is visible on job listing pages but job location is not visible on the single job page. I am senfing you the pronshot of the problem. kindly check and rectify the problem
6 years, 11 months ago #1073467This reply has been marked as private.6 years, 11 months ago #1073477This reply has been marked as private.6 years, 11 months ago #1073479Also Google Webmster not index Job Pages because of missing field Missing field "datePosted" on the Jon Pages
Kindly check your theme and add missing fields for Missing field "jobLocation" and Missing field "datePosted" on the Single Job Listing page view.
6 years, 11 months ago #1073569This reply has been marked as private.6 years, 10 months ago #1073927Kindly check these filed while updating your new version if possible.
As it does not affect the site anyway but for Google Webmaster it is considered as indexing the site for Jobs.
6 years, 10 months ago #1073965Hi.
Thank you for contacting us and sorry for the late response.
To fix that issue, please go to customizer/ Job & Company/ Single job and enable the Schema JobPosting options. It will add the schema to job info.
6 years, 10 months ago #1073982Schema is already enabled, still Google Webmaster showing these errors.
6 years, 10 months ago #1074010Yes, please give us the site admin and FTP account again. We will help you debug the issue.
6 years, 10 months ago #1074280Kindly rectify this problem when you next update your theme
6 years, 10 months ago #1074312
Posts: 3295Hi again, @miqbal
Please provide us with your FTP account again because Jackie wants to check this issue directly on your site. Because we didn't get this issue.
6 years, 10 months ago #1074324This reply has been marked as private.6 years, 10 months ago #1074399This reply has been marked as private.6 years, 10 months ago #1074400This reply has been marked as private.6 years, 10 months ago #1074404DO NOT CHANGE WHAT YOU DID IN MY THEME IN YOUR NEXT VERSION.
You make Header Image STILL in order to make Box Layout Header Image visible. Now all HEADER IMAGES are becoming STILL and not scrolling with the page.
PLEASE DO NOT EDIT YOUR THEME IN YOUR NEXT VERSION what you did in this ticket.
I am now Backup Restore my website and from now using Full Width normal layout for the theme because your Box Layout is USELESS.
DO NOT EDIT YOUR THEME as you did in this ticket rather do other things.
6 years, 10 months ago #1074437Kindly release and update your next version with this problem sort out.
6 years, 10 months ago #1074462
Firstly, please don't change your information during the support time. It is convenient for us to help you check the issue directly.
Secondly, the issue appeared on Google Master, it isn't our issue so we need your information exactly then our developer will have access to your site and check it directly.
In addition, we also help you to fix the header background issue.
