NooTheme Premium WordPress Theme › Forums › JobMonster › Job Category and Job Location not working
- This topic has 9 replies, 3 voices, and was last updated 6 years, 1 month ago by
6 years, 1 month ago #1084817
Hello there,
When I click on the job location and Job category fields I get no response. In the resume section and profile section too... none of the fields are working. I click on them and get no response. What is going on and how can I fix it?
Also, is it possible to convert the advanced search option for the location from a dropdown to a type-in? Like instead of dropping down a menu, the user types in the Zip code, city, state or country?
Thank you and look forward to hearing from you
6 years, 1 month ago #1084848Hi
Thank you for feedback us
You can send information login admin ( set private reply)
I will check the problem for you soon
6 years, 1 month ago #1084871This reply has been marked as private.6 years, 1 month ago #1084878This reply has been marked as private.6 years, 1 month ago #1084907Hi
What is the Url your site?
6 years, 1 month ago #1084909This reply has been marked as private.6 years, 1 month ago #1084923Hi,
I can't login your site with the info above.
Please check again.
Searching for a job requires fields that are accurate to return results. If user enter incorrect keyword -> Results will not be returned. These fields need to be displayed based on data from the database.
6 years, 1 month ago #1084942Hi,
Problem 1:
There seems to be a conflict of the bootrap js library between the "Tabs Pro wpshopmart" and "Jobmonster" plugins. You can deactivate this plugin and try again.
6 years, 1 month ago #1084946Hey, I see that you or someone already deactivated that plugin and it now works. Thank you! However, I needed that plugin to present our "about us" page in a tabbed format. How do I do that? Any other plugins you recommend that will give me the same effect without the conflict?
6 years, 1 month ago #1084987 -
