NooTheme Premium WordPress Theme › Forums › JobMonster › Job Alert NOT WORKING (Noe sure)
- This topic has 10 replies, 3 voices, and was last updated 5 years, 10 months ago by
5 years, 11 months ago #1117452
I have set job alert on my personal email for testing purpose to get mail Daily and I have not received any email from past many days. I am not sure whether my clients are also able to get alert mails or not.
Can we have any mechanism to check and test it?
5 years, 11 months ago #1117616Dear, to check it, please check email function is work on your hosting, you can use some plugin to check it or sample check with Forgot Password form of wordpress.
5 years, 11 months ago #1117618But how above mentoined method will help me check on Job Alert mails?
I am getting usual user registration mails which prooves that email functionality is working fine
5 years, 11 months ago #1117636Yes, If you want test Job Alert actions of Candidate, please login as Employer and create new Job with title like your job alert Keyword and like 'Job Category, Job Type, Job Location...'
5 years, 11 months ago #1117638i have done that already
5 years, 11 months ago #1118143Hi,
You can do the following to check Job Alert functionality:
1, Install plugin WP Crontrol: https://wordpress.org/plugins/wp-crontrol/
2, Create a Job Alert with keyword: eg: Tester.
3, Get ID job alert: http://prntscr.com/s4ialc
4, Go to Cron Events -> click Run now -> http://prntscr.com/s4ibwg
5, Check email: http://prntscr.com/s4icqk
5 years, 11 months ago #11181465 years, 11 months ago #1118156I am not sure from why these error happened! Seems like "user menu" plugin is generating these error!
Since i am not developer, Can you help ?
5 years, 11 months ago #1118770Hi,
We don't develop this plugin, you should contact the author so they can provide a release for these errors.
5 years, 10 months ago #1123571I have request them but I have not received any solution but got an update on plugin...Not sure whether problem is resolved or not! Can you please check if it still have the same problem.If yes, how else can I get Job Alert and Resume Alert feature working?
Can you please suggest any plugins or solutions? I really need that function to be working!
5 years, 10 months ago #1125686Hi,
I have checked the Job Alert function and it is working normally. If you want to check you can follow my instructions earlier.
