NooTheme Premium WordPress Theme › Forums › JobMonster › Issues with Noo Jobs and Noo Resumes function/styling
- This topic has 12 replies, 2 voices, and was last updated 5 years, 8 months ago by
5 years, 9 months ago #1198666
There seems to be an issue with Noo Jobs and Noo Resumes.
With Noo Resumes, your demo works fine, however, if I re-save the element the layout stops working (see attached screenshots - Noo-Resumes.png).
1. Your demo shows a ‘Grid layout’,
2. However, after saving without changing anything it shows as a ‘List layout’.
3. If I change the settings to ’Style Grid’ then nothing appears on the front-end apart from 2 arrows.
4-5. Looking at the HTML with ‘Inspect’, it looks like the HTML changes after saving.
I’ve also noticed that if I add a title, it doesn’t show up in the frontend
With Noo Jobs, Display Style ‘Job List Column’ doesn’t work (see attached screenshots - Noo-Jobs.png).
I added a button but that dissent display.
I’m using WPBakery Page Builder to edit the website and what I’ve also noticed is that adding extra classes to Noo Jobs and Noo Resumes don’t show up in the HTML.
I hope you can help in getting these issues resolved as I really like your theme.
Thanks in advance.
Nic
5 years, 9 months ago #1203065Dear, please kindly send for me admin account and your problem URL via private reply, i will check details problem on your site to help you.
5 years, 9 months ago #1203977Hi,
For security reasons, I don't feel comfortable giving you admin access.
Is there something I can do at my end to fix the issue?
The test URL is: https://notchdesign.co.uk/demo-mini-jobs/home-test/Kind regards
Nic5 years, 9 months ago #1204136You can clone your site and database as demo in sub-domain then send for me to check, because on my localhost, it still working, i think that problem because config on your site, i need check details problem to help you.
5 years, 9 months ago #1204171This reply has been marked as private.5 years, 9 months ago #1204172This reply has been marked as private.5 years, 9 months ago #1204246This reply has been marked as private.5 years, 9 months ago #1204330This reply has been marked as private.5 years, 9 months ago #1204348This reply has been marked as private.5 years, 9 months ago #1204420This reply has been marked as private.5 years, 9 months ago #1204447Dear, please tell for me more details: where setting you choose 3 ? because the Resume in listing page not support change columns.
Also, please kindly update Jobmonster on your site to latest version 4.6.1 and check Job list again.
5 years, 9 months ago #1204468This reply has been marked as private.5 years, 8 months ago #1204517Dear,
I have check Jobmonster again, i see a problem in Noo Resume shortcode with 3 columns. we're will fix it in next update version.Also, i see the style like Image in Jobmonster called job list column, i don't understand why call it that way, for your problem, you can use Job Grid style.
