NooTheme Premium WordPress Theme › Forums › Jobica › Issues
- This topic has 11 replies, 3 voices, and was last updated 6 years, 3 months ago by
6 years, 4 months ago #1081684
Hi i need help to sort the issues out in word
6 years, 4 months ago #1081703
Posts: 155Hi,
1. You go to Dashboard->JM Setting-> Settings at the tab Action Control ,You set the post job field value is "Employer".
2.You need to update the job category field for jobs, then go to edit this page with the elementor page builder and update the Noo Jobs section.
3.Go to Dashboard->JM Setting-> Custom Fields at the tab Job, tick the checkbox "Is Mandatory?" in the field which you want the field to be required when posting jobs.
4.You need to check the box to accept terms before submitting to complete the "Post Job".You can send me admin account (private), if you need help.
6 years, 4 months ago #1082042Hi, the package issue is still not gone.
I want it to allow employers to select post a job and it takes it automatically to the job posting page and not tell them they have no selected package or they need to select a package. I have tried to follow your instructions but it doesnt allow me to post a job at all.
I also need assistance on setting up the jobboard API to allow me to pull jobs from indeed, can you please advise on how i must do this, as Indeed seem not to respond upon the registration.
Please advise on which email i need to send my log in details so that you can log in
6 years, 4 months ago #1082056Hi,
Please send me wp admin info (Set as private reply).
I will help you check.
6 years, 4 months ago #1082059This reply has been marked as private.6 years, 4 months ago #1082069
Posts: 155Hi,
sorry for your time consuming but please send me your website, and i also need your FTP account in case i need to debug.
6 years, 4 months ago #1082171This reply has been marked as private.6 years, 4 months ago #1082173This reply has been marked as private.6 years, 3 months ago #1082188
Posts: 155Hi,
There seems to be a problem with the admin account, I cannot login.
I think your post job problem will be solved if you setup Post Job and View Detail Resume is "Employer".
With the Published ID of indeed you can access this link https://ads.indeed.com/jobroll/signup to create an account and get the published id, it will take a while for Indeed to evaluate and approve your account, we cannot control the process.
6 years, 3 months ago #1082196This reply has been marked as private.6 years, 3 months ago #1082198This reply has been marked as private.6 years, 3 months ago #1082204
Posts: 155Hi,
1, The error may come from your image link, please send me the admin account so I can check it.
-- Currency: Go to Dashboard / Custom Fields / Job and find the job_salary and enter the currency into the Field Value .
