NooTheme Premium WordPress Theme › Forums › JobMonster › Integration for Login & Registration with Linkedin
- This topic has 9 replies, 4 voices, and was last updated 6 years, 5 months ago by
Sanjoob_2019.
6 years, 8 months ago #1076600
As per the provided guide line I am unable to connect because linkden has change its integration settings and JOBMONSTER is not yet update with latest change.
Please look into this asap.
6 years, 8 months ago #1076613
Firstly, please make sure that you have used the latest version of Jobmonster theme. Secondly, have you added the LinkedIn API key exactly?
Then please provide us with your website's URL, admin account and FTP account privately then we will check your issue.
6 years, 8 months ago #1076620This reply has been marked as private.6 years, 8 months ago #1076622This reply has been marked as private.6 years, 8 months ago #1076660
We have got access to your website then found out that you have updated the newest version of our theme.
For your issue, it seems that you haven't added your website's URL to Redirect URLs option in LinkedIn Developers page. Therefore, please refer to this article then add your link exactly: https://knowledgebase.progress.com/articles/Article/login-with-linkedin-throws-an-error-invalid-redirect-uri-this-value-must-match-a-url-registered-with-the-api-key
6 years, 8 months ago #1076871Hi Ttracy,
Reference link which you have shared its not related to the issue which I am facing. Even i checked the link and its a siteinfity crm product of progress which has its own way to integrate with social cahannels.
Further I investigate and found Linkden has changes its login policies from March 2019 and as per it redirect url of Oauth2.0 should have following format.
https://jobmq.com/linkedin-oauth2/callback
I have configured the required URL format in Linkden app settings but the custome code which your team has made its hardcoded in Theme package and only refering https://jobmonster.com.
When user click on linkden registration or login its get the following error because the reidrect url refereing https://jobmq.com instead of https://jobmq.com/linkedin-oauth2/callback
<h3 class="error__message-heading" style="background-attachment: scroll; background-clip: border-box; background-color: transparent; background-image: none; background-origin: padding-box; background-position-x: 0%; background-position-y: 0%; background-repeat: repeat; background-size: auto; border-image-outset: 0; border-image-repeat: stretch; border-image-slice: 100%; border-image-source: none; border-image-width: 1; color: rgba(0, 0, 0, 0.9); font-family: -apple-system,system-ui,BlinkMacSystemFont," segoe ui",roboto,"helvetica neue","fira sans",ubuntu,oxygen,"oxygen sans",cantarell,"droid sans","apple color emoji","segoe ui emoji","segoe ui emoji","segoe ui symbol","lucida grande",helvetica,arial,sans-serif; font-size: 24px; font-style: normal; font-variant: normal; font-weight: 400; letter-spacing: normal; line-height: 32px; orphans: 2; outline-color: invert; outline-style: none; outline-width: 0px; text-align: left; text-decoration: none; text-indent: 0px; text-transform: none; vertical-align: baseline; -webkit-text-stroke-width: 0px; white-space: normal; word-spacing: 0px; border-width: 0px; border-color: rgba(0, 0, 0, 0.9); border-style: none; padding: 0px; margin: 0px;">Bummer, something went wrong.</h3>The redirect_uri does not match the registered value
URL Genrated by the theme: (https://jobmq.com)
https://www.linkedin.com/uas/oauth2/authorization?client_id=81xdkn61zg4jvi&redirect_uri=https%3A%2F%2Fjobmq.com%2F&response_type=code&scope=r_liteprofile+r_emailaddress&state=itvU5s40rbma
Theme should generate following link: (https://jobmq.com/linkedin-oauth2/callback)
https://www.linkedin.com/uas/oauth2/authorization?client_id=81xdkn61zg4jvi&redirect_uri=https%3A%2F%2Fjobmq.com%2Flinkedin-oauth2%2Fcallback&response_type=code&scope=r_liteprofile+r_emailaddress&state=itvU5s40rbma
I appreciate to release the quick fix for the identified issue or you can directly fix it in my domain site, as you already have all required credential details to login and update.
Regards,
JOBMQ Team
6 years, 8 months ago #1076932This reply has been marked as private.6 years, 8 months ago #1077110Thanks for resolving the issue.
6 years, 8 months ago #1077113
Posts: 3295This reply has been marked as private.6 years, 5 months ago #1079923This reply has been marked as private. -
