NooTheme Premium WordPress Theme › Forums › Jobica › Import jobs from Indeed.com
- This topic has 23 replies, 5 voices, and was last updated 6 years, 2 months ago by
6 years, 8 months ago #1080176
How come it doesn't import the job description?
6 years, 8 months ago #1080180
Posts: 155Hi,
We have found the problem of this feature.Please send FTP account, I will check it for you.
6 years, 8 months ago #1080182This reply has been marked as private.6 years, 8 months ago #1080183This reply has been marked as private.6 years, 8 months ago #1080203
Posts: 155This reply has been marked as private.6 years, 8 months ago #1080218This reply has been marked as private.6 years, 8 months ago #1080221Hi,
We login with FTP account above, but the folder is empty.
I can't do anything with an empty folder.
Please check again.
6 years, 8 months ago #1080232This reply has been marked as private.6 years, 8 months ago #1080239This reply has been marked as private.6 years, 8 months ago #1080244
Posts: 155Hi,
I fixed import jobs indeed .I am checking the problem of jooble.org.
6 years, 8 months ago #1080252This reply has been marked as private.6 years, 8 months ago #1080254This reply has been marked as private.6 years, 8 months ago #1080260This reply has been marked as private.6 years, 8 months ago #1080264
Posts: 155Hi,
1.Error at jobs/display=grid , I fixed it.
2.Because it is a job indeed description, we cannot customize the text color for the headlines.You can change the color in the file noo.css .
3.If you have a sample CSV or XML file you can use it to import into category taxonomy or location taxonomy.You can refer to the jobmonster's document.
6 years, 8 months ago #1080337This reply has been marked as private.6 years, 8 months ago #1080349
Posts: 155Hi,
I fixed it.You can check it again.
6 years, 8 months ago #1080897This reply has been marked as private.6 years, 8 months ago #1080973Hi again.
For the jooble job import, it also depends on the API create for each country.
For the Job Location or Job Category XML import, please check the Knowledgebase at this link:
http://wp.nootheme.com/docs/jobmonster/#tutorial
6 years, 8 months ago #1081030This reply has been marked as private.6 years, 8 months ago #1081078
Posts: 87Hi again,
Please follow this image for more details: http://prntscr.com/psjujw
Please check it, then feedback us soon.
Thank you very much!
6 years, 3 months ago #1086475This reply has been marked as private.6 years, 3 months ago #1086502Hi,
You can use plugin to export data or you can enable RSS on company page:
Customizer -> Job & Company -> Companies List -> RSS button
6 years, 2 months ago #1128805This reply has been marked as private.6 years, 2 months ago #1129214Hi,
You can download the last new version here and try again:
