NooTheme Premium WordPress Theme › Forums › JobMonster › Https issues and other points
- This topic has 10 replies, 2 voices, and was last updated 5 years, 11 months ago by
bvalid.
5 years, 11 months ago #1107149
I have some some points that I can't solve:
1- issues with https:, my site appear in browsers as non secure, I tried to use "search & replace" plugin and replaced all "http://" with "htpps://" the site still appear unsecured.
2- The language of the site is french I translated main areas, but some fields still appear in English, I tried the plugin "Loco Translate" but the fields still appear in English.
3- I want to prohibit users from adding new locations but I don't find How.
4- I have Google maps error, the map appear for one second than disappear and in its place the is an error message.
Thank you in advance
5 years, 11 months ago #1109134Dear.
1. I don't understand your problem with https, please tell for me more details.2. Please give for me mode details or problem url on your site, i will check to help you translate it.
3. To disable Custom add new Location, please go to admin menu 'Jobmonster -> Custom fields -> Job' change 'job_location' field type to 'Multiple Location' and check again.
4.I think that problem with Google Map Api, please go to admin menu 'Jobmonster -> Settings -> Location' and check Google Map Api setting again.
5 years, 11 months ago #1110063Thank you for your answer:
1- I bought an SSL certificate and installed it, but all browsers show site as non secure
Chrome
Firefox
2- I almost translated all fields except the search field "Enter job title"
3- Solved thank you 🙂
4- For Google maps I'm struggling with different API options so I think I'll deactivate it for now.
5 years, 11 months ago #1110065site link: myjob.tn
5 years, 11 months ago #1110316Dear.
1. Please kindly contact with SSL provider support to help you check it.2. You can't translate "Enter job title" ? please send for me admin account your site via private reply, i will check to help you.
5 years, 11 months ago #1110612This reply has been marked as private.5 years, 11 months ago #1110620Dear, to translate 'Enter job title' you can use Loco plugin to translate it in plugin 'Jobmonster Elementor Addon '
5 years, 11 months ago #1110624Hello,
As mentioned in my first comment:
5 years, 11 months ago #1111336Dear dangdv,
You asked for an admin account to solve issue 2, I don't understand that after I gave you the access you bring me 3 steps backward with that standard answer !
5 years, 11 months ago #1111857Dear, i have check again and create new translate for Jobmonster Elementor Addon plugin in Loco and check translate, it's working, please check your site again.
best regards.
5 years, 11 months ago #1111893Dear dangdv,
Thank you very much, translation is OK.
