- This topic has 3 replies, 2 voices, and was last updated 7 years, 1 month ago by .
Viewing 4 posts - 1 through 4 (of 4 total)
NooTheme Premium WordPress Theme › Forums › Palazzo › How to fix image sizes
Hello again! I see the theme is pulling image size for the property grid boxes as 370X250 and I'm actually using 2 column layout using CSS and the images are being blurry because the source is smaller than the CSS sizing of the image to show.
Please check this screenshot: http://prntscr.com/mldsqr
How do I change the image size and increase it so a high resolution image is pulled? Thanks for the awesome support always. I rated you guys 5 stars! 🙂
Hi again,
We also got access to our website then checked this issue. Then we found this was our issue.
In this case, we discussed with our developer about it. After that, they are going to fix it.
Please wait for us, we will add it to next version of Palazzo theme. In addition, if you want to fix it, please check your information correctly.
I have fixed this by changing thumbnail size in the code of the theme itself.
You can see the screenshot here: http://prntscr.com/mnt0ot
Of course you have to use the image size registered in the theme. Just posting the solution if someone runs into the same issue. You can mark this issue as resolved too.
Hi again,
We also fixed this issue on our website. After that, we will release the newest version of Palazzo as soon as possible. Thus, you can update it to see our fixed.
