NooTheme Premium WordPress Theme › Forums › JobMonster › How to Add 2 button?
- This topic has 111 replies, 3 voices, and was last updated 6 years ago by
6 years, 4 months ago #1081259
I have 2 questions
1. How to attach both Post Resume and post Job button for Guest user?
I understand that I have make some modification in this file "/wp-content/themes/noo-jobmonster/framework/functions/noo-wp-style.php" but exactly what change? please specify!
2. When i see website in mobile view, I get search bar moves down, below image. Image attached for reference. How can i make it more organised as aesthetic?
6 years, 4 months ago #1081262I also find that my sub-menu is not visible in mobile view but I can see that in Desktop view. How can I enable that? Image attached for reference
6 years, 4 months ago #1081273Hi,
Please send me wp admin account (Set as private reply).
I will help you check.
6 years, 4 months ago #1081376This reply has been marked as private.6 years, 4 months ago #1081379Also I am also not able to access job page details ( https://genuinehires.com/jobs/ ) using WPBakery or Elementor.
I want to add "job by categories", "Job by location" and "Job by Types" as short links in Footer.
How can I do that?
6 years, 4 months ago #1081394Hi,
You should first use the child theme for these customizations. If you customize the parent theme, it will be lost when you update the new version.
After you active Child Theme, you can add this function to the functions.php file of Child Theme (attachment)
I added these lines to Custom CSS:
@media(max-width: 992px){.sub-menu li.align-left{
float: none;
Also I am also not able to access job page details (https://genuinehires.com/jobs/) using WPBakery or Elementor.
This is the job archive page (default job page ). WPBakery & Elementor currently only supports custom pages and single pages. You can create a custom job page and customize for it.
You add the Noo Job to widgets "Noo Footer 1->4" and change settings for each widget
6 years, 4 months ago #1081409Hi
"You should first use the child theme for these customizations. If you customize the parent theme, it will be lost when you update the new version."
How to use "child theme" so that my current modifications are not lost? Can you please do that for me?
6 years, 4 months ago #1081418Hi,
Please send me FTP account.
I will help you add the Child Theme.
6 years, 4 months ago #1081427Hi
I think I have managed to setup child theme but I have few more silly issues.
In footer section, when I have attached job by location and job by category:
1. I cannot see all jobs from different locations already posted. It just pick on 1 job.Why?
2. Heading "job by location" and "job types" are not highlighted. How to do that?
I have attached screen shot for your reference.
6 years, 4 months ago #1081432Hi,
1, Please enter the number display field.
2. I added these lines to Additional CSS:
.wigetized .noo-job-type-widget h4.widget-title, .noo-job-location-widget h4.widget-title{
color: #fff!important;
6 years, 4 months ago #1081447Hi
I need someone to give me second level of search bar for micro refining
Ex: Lets say at first level, out of total 10000 jobs available, we filtered 1000 jobs based upon Keyword,category and location.
I further want to apply micro filter on these 1000 jobs based on other criteria such as salary, interview location, etc. so that I could identify only 50 jobs based upon my exact requirements. I want the similar micro filtering in Resume search also.
So, to get this second kind of filtering, I need someone who could design this for me. Can you connect me with someone (in case available within your team) and relevant charges?
I need it quick so please help me in this.
6 years, 4 months ago #1081480Hi,
Jobmonster currently support widget "Advandce Search" and Filter widget for both Job and Resume. You can try using it, hope it helps.
6 years, 4 months ago #1081507Hi
Thank you for your constant help.
In my website, "www.genuinehires.com" , Homepage of my website looks different in my mobile and laptop.
Center Text and Search bar seems shifted. How can I correct it? please look and help.
6 years, 4 months ago #1081508Hi,
Also In the job page, job location widget is not displaying all job locations.
Please correct it
6 years, 4 months ago #1081509Hi
I think I have solved the immediate previous issue.
Now, can you help me here:
1. In my website, "www.genuinehires.com" , Homepage of my website looks different in my mobile and laptop. Center Text and Search bar seems shifted. How can I correct it? please look and help.
2. I am not able to "search resumes" properly in Resume page. Search tool is not behaving properly. Please check!
6 years, 4 months ago #1081516Hi,
Please me some screenshot to clarify.
6 years, 4 months ago #1081519please find the attached screenshots.
Screen shots are referring to 4 different problems:
1. Yellow color in login button even when theme have Green color
2. in mobile view, center text and search bar is shifted much below the wallpaper
Please check
6 years, 4 months ago #10815212nd problem screen shot
6 years, 4 months ago #10815222nd problem
6 years, 4 months ago #10815243. Both main Search bar and side search bar in resume page does not seems to work!
Screen shot
6 years, 4 months ago #10815253rd problem screenshot attached
6 years, 4 months ago #10815284th: main and side Search bar not working in Top job page also
screenshot attached
Please help me with the solutions and also tell me how to solve it
6 years, 4 months ago #1081546Hi,
1, Search issue: Please uncheckbox this option in WP Content Private plugin
2, Text issue: I addes some lines to style.css of Child Theme.
6 years, 4 months ago #1081563Hi
I have got update for my theme.
I have setup child theme as suggested by you but I need you to recheck whether I have made currect setup for same. I am asking you to check because I have lost my customization once for some reason and dont want it to happen again. So please check and give me go/no go!
wp-admin Login details have already been shared in my previous post
6 years, 4 months ago #1081564Thank you for all your previous help.
Really appreciate it !
Also correct this
"Without login, when i hover on Register button, it shows Yellow color even when theme have Green color"
