NooTheme Premium WordPress Theme › Forums › LandMark › How do I right align menu items in my Header?
- This topic has 15 replies, 2 voices, and was last updated 5 years, 2 months ago by
Wal.
5 years, 3 months ago #1210935
Hi there,
Previously my menu items were right-aligned (with logo to left). They are now left-aligned. How do I change this back, please?
I would also like to add a phone number (when upon click brings up the number on a mobile device). How do I add this to the right of "Contact Us"?
5 years, 3 months ago #1210975Dear.
The default menu of LandMark is left align, if you want change to right, Please add custom CSS code on your site..header_classic .noo-main-menu { float: right; }Also, i don't understand what you want add mobile number, please kindly give more details with screenshot or demo url, i will check to help you.
5 years, 3 months ago #1210981This reply has been marked as private.5 years, 3 months ago #1210997Dear, I can't login to your site with account your send. please kindly check again.
5 years, 3 months ago #1210999This reply has been marked as private.5 years, 2 months ago #1211059Dear, To add Phone number on header, please go to Customizer -> Header and add your phone number in setting 'Add Phone Number'
5 years, 2 months ago #1211061This reply has been marked as private.5 years, 2 months ago #1211088Dear,
1. Sorry, the theme not support display phone number on small screen.2. To remove space, please go to edit page with WPBakery then click edit row (see attachment) to remove 'noo-margin-top-100' in 'Extra class name' setting.
5 years, 2 months ago #1211096Hi there,
Apologies, but I'm unable to follow these instructions. I cannot find all the info mentioned.
Thank you,
5 years, 2 months ago #1211110Hi there,
I actually want to ensure there IS a buffer. How do I make sure is in place?
See the attached:
I also cannot understand why the logo is distorted? The height is greater than it should be.
5 years, 2 months ago #1211116Dear, If you want add space, please click edit row and add padding like attachment. Also, i can't see problem of Logo like your screenshot, Please kindly send for me your problem URL via private reply, i will check details to help you.
5 years, 2 months ago #1211173Hi there,
Thank you for your help, almost there!
I just have to figure out now, why the phone details at the RHS in the header does not sit within the header.
Thank you!
5 years, 2 months ago #1211221Dear, I have add custom CSS to fix phone number on header, Please check your site again.
5 years, 2 months ago #1211239Hi there,
That looks truly amazing.
A final question. Why would two different browsers display the logo differently? Safari is as I want it, but Chrome is not. See attached.
5 years, 2 months ago #1211313Dear, That problem because CSS render of chrome and safari is different. I have add custom CSS to fix that problem. Please check your site again.
5 years, 2 months ago #1211350This is perfect!
Thank you so much.
Please mark this ticket as resolved.
