NooTheme Premium WordPress Theme › Forums › JobMonster › Homepage layout
- This topic has 10 replies, 2 voices, and was last updated 5 years, 9 months ago by
5 years, 9 months ago #1177342
hey our homepage blocks became boxed without changing anything please fix that issue , specially ist block , second last and last one , our site in full width setting but these blocks have something wrong suddenly ,
and there is space as well between last block and footer
5 years, 9 months ago #1178094Dear, i have check your site i see a javascript error (like attachment) if you use cache plugin to cache javascript, please check cache plugin on your site to ignore cache jQuery, if you can't check setting, please kindly contact with plugin author to help you.
best regards.
5 years, 9 months ago #1178110So you want me to un install that plugin ?
5 years, 9 months ago #1178839This reply has been marked as private.5 years, 9 months ago #1180438Dear, To fix your problem, you need select 'Page Template' of your home page is 'Full Widget'.
Why you move page template of Jobmonster theme to folder 'temporary' ? That cause error (can't use WPBakery Page Builder) when select page template of Home page is full width. please remove it and select page template of Home page to full width again.
5 years, 9 months ago #1181881Really i dont understand what you said can you do it for me or can you explain it with screenshot please
5 years, 9 months ago #1181888yes i understand thanks problem solved , please mark as resolved.
5 years, 9 months ago #1181911This reply has been marked as private.5 years, 9 months ago #1184268I not see code on your home page, please check again.
5 years, 9 months ago #1184785This reply has been marked as private.5 years, 9 months ago #1185842You don't read my reply ? I see jobmonster theme on your site have folder 'temporary' (like attachment) it cause error on your home page. What is folder ? I have told you so many times, Please don't custom/add/edit any code in jobmonster theme folder, please switch your site to use Jobmonster child theme to add custom.
