NooTheme Premium WordPress Theme › Forums › JobMonster › Home page layout
- This topic has 11 replies, 3 voices, and was last updated 6 years ago by
furiopiccinini.
6 years, 1 month ago #1085553
Hello there! I would like to have my home page similar to the attached picture, with the chance to choose between Employer or Candidate profile. Can you help me set things up in this way?
my site is missionelavoro.eu
thanks
6 years, 1 month ago #1085555Hi,
Can you upload attached photos?
6 years, 1 month ago #1085556Sorry, I sent the ticket by mistake. Here's the picture.
Each button should show the Register form for each type of user, but How can I achieve that?
6 years ago #1085616Hi
Do you want add wiget Register User as in image
You want to install it on any page I will add it for you, or you want me to guide you to add it ?
6 years ago #1085620If you can guide me it's a better choice, so I can learn more. Thank you!
6 years ago #1085625Hi
Please go to edit page -> WPBakery Page Builder -> add a Row with 2 column -> select "Register user"
and then enter the parameters for the config and save the page
Hope you understand
6 years ago #1085631Again... I'm not using Page Builder! I use Elementor!
6 years ago #1085642Hi
Please edit page with Elementor -> Add Section -> add Widget "Noo Call To Action "
Hope it will help you
6 years ago #1085807Hello, I did what you suggested but Noo Call to Action is not what I asked for. Can I have your help please?
6 years ago #1085809I created a new page called "Home", which has only the widget you suggested me, but seems completely different from what I asked (check my previous picture attached). I need 2 buttons, that brings users to the login page for Employer (left choice) and Candidate (right choice).
6 years ago #1085843I have created a shortcode for you like in the image that you requested as a model please go to the home page and check
6 years ago #1085927It's in the wrong page but it's exactly what I meant! Thank you! I'll save the payout as a template and move it to a different page.
