NooTheme Premium WordPress Theme › Forums › JobMonster › Help, how do I change the font colour of a Fixed top navigation bar
- This topic has 30 replies, 3 voices, and was last updated 6 years, 9 months ago by
7 years ago #1070434
I want to know how to change the font colour of the navigation bar. I set the header to transparent and in the transparent state, the font colour is white, which is fine. But there is a problem whenever I scroll downwards, the font colour still remains white which makes it disappear to the background.
Please, I will like to know how to change this colour to black (#000000)
P.S. I want the colour of the fixed navigation bar to change to black when it scrolls down and not remain white (I set the header to transparent). So, I want it to change to black whenever I scroll down so that it won't blend and disappear to the background.
7 years ago #1070451
Please give us your link privately via checking Set as private reply checkbox. Because we want to check your website directly.
7 years ago #1070509This reply has been marked as private.7 years ago #1070512This reply has been marked as private.7 years ago #1070516This reply has been marked as private.7 years ago #1070555
Posts: 3295This reply has been marked as private.7 years ago #1070614This reply has been marked as private.7 years ago #1070615This reply has been marked as private.7 years ago #1070673
Posts: 3295This reply has been marked as private.7 years ago #1070717This reply has been marked as private.7 years ago #1070742Hi again.
To use Loco Translate to change the string in the theme, you can follow our document at this link
http://wp.nootheme.com/docs/jobmonster/#how_to_rename_translate_any_word
And can you give us your site admin account? We need to check the setting to help you fix the issue with the company footer.
7 years ago #1070782This reply has been marked as private.7 years ago #1070813
We added this Custom CSS segment to Customier> Custom Code > Custom CSS to fix the header issue:
.navbar.navbar-default.fixed-top.shrinkable.navbar-fixed-top.navbar-shrink a {
color: black !important;
7 years ago #1070967This reply has been marked as private.7 years ago #1070982
Posts: 3295This reply has been marked as private.7 years ago #1071092This reply has been marked as private.7 years ago #1071118
You can go to your Dashboard> Updates then see the updated notification. However, some servers aren't compatible with our server, therefore some customers didn't see an updated notification. In case, please go to ThemeForest market, then download the newest version of Jobmonster theme, find the theme package then add it via WordPress or FTP. Nevertheless, don't forget to backup all the customization files before updating or writing them to your child theme.
7 years ago #1071188Please, can you give a link on how to back up customization to a child theme?
Thanks7 years ago #1071217
Please refer to this link to learn more about Child Theme:https://themefuse.com/child-themes-what-they-are-how-to-use-them-and-why/
In addition, we also supported a child theme file, so you can upload it to your website then write your custom files in it.
6 years, 9 months ago #1075842This reply has been marked as private.6 years, 9 months ago #1075904
Firstly, please provide us an image which describes the section you want to change the color. After that, you should check again the resume page because there aren't resumes in here. Also, see this image: https://prnt.sc/o2q0sg
In addition, you should give us your admin account and FTP account too, because we need to get access to your website directly and see the issue.
6 years, 9 months ago #1075953This reply has been marked as private.6 years, 9 months ago #1075978
Posts: 3295This reply has been marked as private.6 years, 9 months ago #1076008This reply has been marked as private.6 years, 9 months ago #1076043There is no response still, what is happening?
