NooTheme Premium WordPress Theme › Forums › JobMonster › Header photo and job location map not showing on job offer pages
- This topic has 6 replies, 2 voices, and was last updated 10 months ago by
10 months, 1 week ago #1222488
We are in the development of a new website https://www.aflex.sg-host.com/ with Job Monster in Elementor.
On single job offer pages, the header photo and the bottom map with job location are not showing.
Any idea why?
10 months, 1 week ago #1222505Hello,
Any chance someone could answer me? We are stuck until we can solve this.
On the attached screenshots, you can see the single job page without a header photo and with a blank map, while the job offer is correct in WP admin: You can see the cover photo and the location, and you can see the job page with the global map showing all locations. So, the problem is only with the single job template.
You must be logged in to view attached files.10 months ago #1222521Hi.
I have checked and fixed that issue on your site. You have missed the Zoom level config under the JobMonster/ Settings/ Location.
Now you can see the map.
10 months ago #1222523Fantastic, it works, thank you, Jackie!
And for the second issue on the same page: missing cover image, could help ?
You can see on the attached screenshot that the cover image is correct in the back office, but doesn't show on the job page.
You must be logged in to view attached files.10 months ago #1222537Hi.
I have checked and fixed the page cover issue on your site.
10 months ago #1222538Than you Jackie!
Yes, form a technical side, it works. But we can't keep this display. How is it possible to edit the image settings: remove the parallax, set the display to "cover", align middle-middle, ... I can't find any setting for that. It there is no direct setting, where could it be changed (PHP, ...) so our webmaster could do it.10 months ago #1222539Hi.
To turn off the parallax background for the page heading, please go to customize/ Design and layout. Then you will see the option to turn off the "Enable Parallax Background" option.
