NooTheme Premium WordPress Theme › Forums › Palazzo › geolocalisation not working as Ignored
- This topic has 5 replies, 2 voices, and was last updated 5 years, 7 months ago by
5 years, 7 months ago #1205554
url site floriangeraud.com .
when i set google api key , i have this error:
js?v=3.exp&libraries…s&language=fr_FR:79 Geocoding Service: You must use an API key to authenticate each request to Google Maps Platform APIs. For additional information, please refer to http://g.co/dev/maps-no-account<tbody>
_.re @ js?v=3.exp&libraries…s&languag </tbody>
Thanks lot for your return.
<tbody>
</tbody>
5 years, 7 months ago #1205630Dear, i think that problem of your google api key. please check again or read more in http://g.co/dev/maps-no-account
5 years, 7 months ago #1205729Hi,
My google api key is configured correctly for the Maps Javascript api and the Geocoding api
I added it in the Palazzo theme options.
Now the front-end maps are working perfectly.
The problem remains in the admin area when i'm logged, none of the admin maps neither the geocoding request made by the single property page work...
I'm a web developper so i analysed the html source code and i see that the google map script does not contain any api key !
<script src='http://maps.googleapis.com/maps/api/js?v=3.exp&libraries=places&ver=1.0'></script>
I think the theme has a problem as my api key given in the theme options is not appended internally to the google maps js call.
It can't work in admin without the key .
I really need to have the maps and geocoding requests to work in admin.
Thank you for your help
5 years, 7 months ago #1205813Dear,
I check Palazzo theme again, i see the theme load map script is correct and Google Map still working, Please check your site again, if your site still use Palazzo theme and plugins old version please update to latest version:Palazzo theme 1.2.3
Noo Palazzo Framework plugin 1.2.3
Realty Portal plugin 1.2.5If your site use plugins and theme latest version but google map still not work, please kindly send for me admin account and your problem URL via private reply, i will check details to help you.
5 years, 7 months ago #1205883This reply has been marked as private.5 years, 7 months ago #1205951Dear, that problem because you not add Google Map API, please go to admin menu 'Realty Portal -> Settings -> Map & Location' to add Google Map API.
