NooTheme Premium WordPress Theme › Forums › JobMonster › General INformation – Post Resume Page need to edit
- This topic has 23 replies, 3 voices, and was last updated 6 years, 10 months ago by
6 years, 11 months ago #1073147
Dear Team,
i am very happy to work on your theme..and its really helpful
just find the attachment and help me with the process how to edit same.
might be the POST -Resume form as per my requirement need to change at most places
will wait for your reply
thanx in advance
6 years, 11 months ago #1073192
You can use Loco Translate plugin then translate these texts to your texts. Because they are contained in our language file.
In addition, you can go to JM Jobmonster > Custom Fields> Resume then disable Highest Degree level like this image: https://prnt.sc/nh0wsp
6 years, 10 months ago #1073377Dear Team,
Its very grateful as you have answered all my queries in time so i am able to accomplish my requirement.
going forward when user trying to access my webpage through mobile browser the header content and logo overlap the page content(where it should work as responsive)
will wait for your reply.
6 years, 10 months ago #1073447
Because your logo is too large on mobile device, that's the reason why you got this issue.
In this case, please add this Custom CSS segment to Customizer > Addition CSS to fix it:
@media(max-width:768px){
.navbar-brand .noo-logo-mobile-img{
max-height:85px !important;
6 years, 10 months ago #1073455hi,
After adding the CSS, its not working for all pages
few got resolved and few still overlapping.
Regards,
Girish Surve
6 years, 10 months ago #1073514
Please provide us with your website's URL & admin account privately via checking Set as private reply checkbox. We will help you to check this issue.
6 years, 10 months ago #1073546This reply has been marked as private.6 years, 10 months ago #1073573while checking the SITE performance on GTmetrix the yslow score is following down due to attach JS and not cookie free content.
how to get this solve
6 years, 10 months ago #1073625
We have got access to your website then helped you to fix the issue related to your logo issue.
For the GTmetrix calculation, our developer is checking it, then we will feedback you soon.
6 years, 10 months ago #1073629Hi again.
We have checked and fixed the issue with heading page on the mobile.
With the yslow check, I found some article about that. Maybe it can help you config and optimize the site.
https://community.cloudflare.com/t/gtmetrix-is-saying-i-need-to-use-cookieless-domains/3254/2
https://community.cloudflare.com/t/use-cookie-free-domains-possible-solution/46091
https://bloggersdayout.com/use-cookie-free-domains/
6 years, 10 months ago #1074039hi Tracy,
On your suggestion i have installed pLugin LOCO and replace one of the text "I am Candidate looking for Job" to "I am Driver looking for Job".
but same is not getting effected in Website.
after going again in loco i see Driver properly.
kindly check as i have already shared Credentials with you.
Thanks in Advance.
Regards,
Girish
6 years, 10 months ago #1074079
Please provide us with your admin account and FTP account again. After that, we will help you to check this issue.
6 years, 10 months ago #1074202Hi Tracy,
As account details are already shared with you..
kindly update me on above query.
Regards,
Girish Surve
6 years, 10 months ago #1074231
Did you change the source code directly?
Because when we used Loco Translate plugin, it changed before: https://prnt.sc/noopkg
In this case, please tell us which file did you change?
In addition, please provide us with your FTP account - this is an ount which we can have access to your source code. You have just given us your admin account.
6 years, 10 months ago #1074273This reply has been marked as private.6 years, 10 months ago #1074308
You forgot to give us your hostname so please send us it. In the meaning time, you can try to go to {root}/\wp-content\themes\noo-jobmonster\layouts\forms\register-social-form.php line 26 then change this text directly in the source code. Also, see the attached image below.
Check it, then feedback us.
6 years, 10 months ago #1074344Hi Tracy,
as you suggested i have change the code directly, but still the same is not effected.
please find the attach files..
also let me Know which hostname you required to get inside.
6 years, 10 months ago #1074356
Posts: 3295This reply has been marked as private.6 years, 10 months ago #1074373Hi Tracy,
I login to code through Cpanel under below URL
Username : gadidriv
Password : Lenovo@123&*12
6 years, 10 months ago #1074374This reply has been marked as private.6 years, 10 months ago #1074375This reply has been marked as private.6 years, 10 months ago #1074391
Posts: 3295This reply has been marked as private.6 years, 10 months ago #1074401This reply has been marked as private.6 years, 10 months ago #1074444
Our developer has got access to your source code and change in it. After that, they cleared your cache and checked again on your site.
If you have any question, don't hesitate to ask us. We are ready to help you.
