NooTheme Premium WordPress Theme › Forums › Other Products › Noo Products Layouts › Filters not working.
- This topic has 19 replies, 2 voices, and was last updated 5 years, 7 months ago by
Inlay.
5 years, 7 months ago #1206244
The layout is displayed fine. But the filters are not working. The "sort by" function is displayed but not working.
Can you please look into it? Here is the link for our shop page. https://pari.<wbr />mystagingwebsite.com/shop/
Awaiting your response
Best Regards
5 years, 7 months ago #1206266Dear, please kindly send for me admin account your site via private reply, i will check details to help you.
5 years, 7 months ago #1206305This reply has been marked as private.5 years, 7 months ago #1206313This reply has been marked as private.5 years, 7 months ago #1206342This reply has been marked as private.5 years, 7 months ago #1206371This reply has been marked as private.5 years, 7 months ago #1206388This reply has been marked as private.5 years, 7 months ago #1206416Dear, I check plugin again i see a error in plugin code, i have fixed it, please check your site again.
5 years, 7 months ago #1206420This reply has been marked as private.5 years, 7 months ago #1206477I fixed code to make sortby to work and this plugin help you to create product list widget in Elementor with style deffine of in pluign and it not support to custom Shop page, mean, compatible with WooCommerce Filter plugin on your site .
5 years, 7 months ago #1206489Hello,
I turned off my berocket filter plugin on my website and checked it again. But still the category filter in this is not working. How to solve this problem? As only one category products are visible.
Also I had a pre sale question about the filter plugin especially that will it be compatible or not. I was told that your team will work in your plugin so that there is no compatibility issue.
Best Regards
5 years, 7 months ago #1206555I check plugin again and i see it not compatible with WooCommerce Filer plugin. Sorry for the inconvenience.
5 years, 7 months ago #1206556Hello,
So how will you fix this issue?
I already told you that I deactivated the woocommerce filter plugin and then also the category filter is not working.
Best Regards
5 years, 7 months ago #1206621Dear, please kindly clearly: The plugin is use custom query to display products on your site, it not use Main Query of shop page to show products, mean, it can't not work with filter on shop page.
5 years, 7 months ago #1206636Hello,
Can you hide the category filter in the noo products layout since it is not working? Also is their a way that your noo products layout work with the be rocket filter plugin? As it is not possible to add each product by custom query.
Best Regards
5 years, 7 months ago #1206678Sorry, because the plugin not work with main query, So, you can use any filter plugins with this plugin.
5 years, 7 months ago #1206681Hello,
Okay how to set noo products layout plugin on my website so that it displays all products?
Can you please solve the main issue i am facing regarding my shop page? Because on my shop page only one category product are been displayed.
Best Regards
5 years, 7 months ago #1206692Dear, please check Setting 'Select category' of widget on Elementor, i think the widget only display product of one category product because you select category.
5 years, 7 months ago #1206696Hello,
We have not selected any category and I have tried adding all the categories in the category tab still only a single category product is visible. I have attached a screenshot for your reference.
Can you please recheck into this?
Best Regards
5 years, 7 months ago #1206698**We have selected all the categories in the "select category" option in elementor.. still only single category product is visible on our shop page.
You can check it in the reference image i have attached in the above thread.
Best regards
