NooTheme Premium WordPress Theme › Forums › JobMonster › Filter Widget not responsive and with bugs
- This topic has 9 replies, 3 voices, and was last updated 5 years, 6 months ago by
5 years, 7 months ago #1205503
Hey there - the Filter widget doesn't work mobile and has bugs. Filters do show UNDER the results on mobile - there is no icon to open/expand the filters on top of the page. People don't find it and leave the page. Once a filter is set, there is an open/close button for the filter OVER the results but nothing happens on click in firefox. In IE a search field slides in (thats not the filter!?) Can be seen in your own Demo! https://wp.nootheme.com/jobmonster/jobs/
5 years, 7 months ago #1205573Dear, that is default style of theme: the widget fiter will display on top of Job Archive page, but on Them Demo has 'Featured Jobs elements' so, you need scroll top to see Filter widget.
5 years, 7 months ago #1205621May be you should get your demo sorted - there is no valid example online how jobmonster should work. Other websites using Jobmonster are old or out of business. I have downloaded the latest theme and the filters (sidebar) do load under the results and on click on the filter icon nothing happens. Like in your demo.
5 years, 7 months ago #1205692Dear. When you not use Feature job section on archive page, you will see filter display like video Please check again.
5 years, 7 months ago #1206315Will you fix this? Featured Jobs are a feature of your theme - so it should not break the layout, right?
5 years, 7 months ago #1206380We're will check again, maybe will hide Featured Jobs on mobile.
5 years, 6 months ago #1207168Hi there,
First: I have same problem like BVGabriel with "Filter" button on archive page. Filter button will appear on mobile, but nothing happens if clicked like in your video !
Second: in search-widget there is no "Search"-button, so it will immediately show results as soon one single category is clicked, even if customer wants to select some more categiries. And on my site there is about 100 categiries to choose from. So it would be great feature to have a "Search"-button, like there is on your video!!!
Maybe I did not find the right setting to display "Search"-button. Please check on my site: https://www.bildungsserver.net/?s=&post_type=noo_jobKind regards, Gunther
5 years, 6 months ago #1207192Dear,
1. The Filter button is fixed on Jobmonster v4.6.5.2 Please kindly update Jobmonster theme on your site to latest version and check again.2. I can't check your site. It give error like attachment, please kindly check your site agian.
5 years, 6 months ago #1207263Hi,
1. how can I update to Jobmonster v4.6.5.2 ?
2. please check my site again, it is online and working. Maybe there was a server-problem at the time you tried.
I changed the widget to the other search widget which has search button.
AND: I want the radius-button in widget to be moved with finger on touch-screen on mobile. Please you expand function on next update.
AND: I want to have the max-distance for local-search increased to 250 or even 500 kilometers. How can I do that? I which file that setting can be changed? Please you increase distance-settings on next update.
Please see attached screenshot.
5 years, 6 months ago #1207309This reply has been marked as private. -
