NooTheme Premium WordPress Theme › Forums › JobMonster › Filter for Companies
- This topic has 18 replies, 2 voices, and was last updated 1 year, 11 months ago by
giszech.
2 years ago #1221035
Hi jobMonster-Team,
I've just updated your theme but recogniced that I cannot filter the companies in the Admin-dashboard. With the old version I could filter the companies from the Dashboard > All jobs
I remember that you have added this option when I installed the jobmonster for the first time and I already worked with such a filter. But this is not possible with the update.
Best wishes
Giszech
2 years ago #1221036a screen shot to compare the old and new version.
best wishes
2 years ago #1221051Hi.
Yes, we have disabled the company filter for the jobs manager to avoid the issue when you have a lot of companies.
If you want to have companies filter, please go to this file: /wp-content/themes/noo-jobmonster/framework/job/admin-job-list.php and remove the command code at lines: 424 to 452.
1 year, 11 months ago #1221089Dear Jackie,
Thank you for your answer - it did not work.
I have found the file ../admin-job-list.php
I removed the lines 424-452 but when I wanted to open the WebSite I got the error message - error on line 424
Could you kindly write the entire code which I should remove. I opened the file with the word-editor > ftp-upload. I had no numbers of the lines and I am not sure whether or not they really were line 424-452 which I removed.
Thanks in advance
Gisela
1 year, 11 months ago #1221097Hi.
This is the code after removing the command. https://i.imgur.com/hWm8WhC.png
1 year, 11 months ago #1221103Dear Jackie,
I still get an error message.
Parse error: syntax error, unexpected '<' in /../../../.../.../jobboerse_klon1/wp-content/themes/noo-jobmonster/framework/job/admin-job-list.php on line 425
There has been a critical error on this website. Please check your site admin email inbox for instructions.
Take a look on the screen-shot of the Code lines, I have removed.
Best wishes
Gisela
1 year, 11 months ago #1221117Hi.
Please give us your site URL, admin and FTP account. We need access your site to help you check that issue.
1 year, 11 months ago #1221118Thanks in advance, I will first update all plugins incl. WP and then send you a private message with the url. Is the Jobmonster compatible to the last WP-Version?
Best wishes
Gisela
1 year, 11 months ago #1221120Hi.
Yes, the theme is compatible with the last WordPress version 6.5
1 year, 11 months ago #1221122This reply has been marked as private.1 year, 11 months ago #1221123This reply has been marked as private.1 year, 11 months ago #1221124This reply has been marked as private.1 year, 11 months ago #1221133This reply has been marked as private.1 year, 11 months ago #1221134This reply has been marked as private.1 year, 11 months ago #1221146Hi.
I have accessed the FTP account to help you edit the source code on this file:
jobboerse/wp-content/themes/noo-jobmonster/framework/job/admin-job-list.php
But I can't access the back-end dashboard with the "support" account. So please recheck the back-end again.
1 year, 11 months ago #1221162This reply has been marked as private.1 year, 11 months ago #1221164Dear Jackie,
I've just seen, the company's filter is back again - great "THANK YOU".
I assume the running version now is jobmonster 7.4.1.
What happens, when you update the theme the next time? Will I have the same problem?
I can imagine, that many others may find a good use for this feature - to filter companies on the dashboard. Propably you might implement it as a standard feature.
Best wishes
Gisela
1 year, 11 months ago #1221167Hi.
Thank you for your feedback.
I'll add the company filter function back on the next version. Don't worry about that.
1 year, 11 months ago #1221171Thanks a lot - have a nice day!
