NooTheme Premium WordPress Theme › Forums › JobMonster › fatal error error not solved
- This topic has 2 replies, 2 voices, and was last updated 2 years, 12 months ago by
3 years ago #1220160
Hello Jackie
When I got user menu profile
the email appears again and again . The problem did not solved. It doesn't change user menu profile .
I can not change color or other setting . Please look at the attached image
and go to the link and check (https://cumillajobs.com/wp-ad<wbr />min/profile.php?logged_in=1)
I have added the errors below
WordPress has a built-in feature that detects when a plugin or theme causes a fatal error on your site, and notifies you with this automated email.
In this case, WordPress caught an error with your theme, Noo JobMonster.
First, visit your website (https://cumillajobs.com/) and check for any visible issues. Next, visit the page where the error was caught (https://cumillajobs.com/wp-ad<wbr />min/profile.php?logged_in=1) and check for any visible issues.
Please contact your host for assistance with investigating this issue further.
If your site appears broken and you can't access your dashboard normally, WordPress now has a special "recovery mode". This lets you safely login to your dashboard and investigate further.
To keep your site safe, this link will expire in 1 day. Don't worry about that, though: a new link will be emailed to you if the error occurs again after it expires.
When seeking help with this issue, you may be asked for some of the following information:
WordPress version 6.2
Active theme: NOO JobMonster Child Theme (version 1.0.0)
Current plugin: (version )
PHP version 8.0.28Error Details
An error of type E_ERROR was caused in line 534 of the file /home/qbgbwgcb/public_html/wp-<wbr />content/themes/noo-jobmonster/<wbr />framework/admin/noo_member.php<wbr />. Error message: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, string given in /home/qbgbwgcb/public_html/wp-<wbr />content/themes/noo-jobmonster/<wbr />framework/admin/noo_member.php<wbr />:534
Stack trace:
#0 /home/qbgbwgcb/public_html/wp-<wbr />content/themes/noo-jobmonster/<wbr />framework/admin/noo_member.php<wbr />(534): in_array()
#1 /home/qbgbwgcb/public_html/wp-<wbr />includes/class-wp-hook.php(308<wbr />): Noo_Member->user_profile()
#2 /home/qbgbwgcb/public_html/wp-<wbr />includes/class-wp-hook.php(332<wbr />): WP_Hook->apply_filters()
#3 /home/qbgbwgcb/public_html/wp-<wbr />includes/plugin.php(517): WP_Hook->do_action()
#4 /home/qbgbwgcb/public_html/wp-<wbr />admin/user-edit.php(844): do_action()
#5 /home/qbgbwgcb/public_html/wp-<wbr />admin/profile.php(18): require_once('/home/qbgbwgcb/.<wbr />..')
#6 {main}
thrown3 years ago #1220162This reply has been marked as private.2 years, 12 months ago #1220182Hi.
We have checked and helped you fix that issue with the user profile page. https://prnt.sc/7rDfWGZL16v0
