NooTheme Premium WordPress Theme › Forums › Timetable › Export feature is not exporting the start and end times
- This topic has 10 replies, 3 voices, and was last updated 7 years ago by
7 years, 1 month ago #1067648
I am seeing the following happening:
For classes that have a 'default start and default end time', the Export ical option is not exporting the start and end times for those. Instead it exports them as 'Full Day'-event.
You can see this on http://www.theyogarescue.com/en/daily-classes
When you use the export option below the schedule and import that into your own calendar -> some are full day events instead of with a start and end time.
Can you help to check the plugin? seems something is not exporting correctly.
7 years, 1 month ago #1067692Hi.
We have checked your site, try to export the calendar then import to our calendar. It still displays the correct time as your site data.
Please check my attach file and feedback us again.
Jackie.7 years, 1 month ago #1067701Hi, no it does not. Please check in your attachement. You see Yin Yoga in the top? It says All Day... and this class has a time if you look in the schedule. So the export is ignoring default times.
7 years ago #1069089Just wanted to check on the status of my above message... As you can see from the attachment you sent, the Yin Yoga on the top says All Day while this is a specific time in the schedule on the website. Still looking forward to hear from you 😉
7 years ago #1069191This reply has been marked as private.7 years ago #1069754This reply has been marked as private.7 years ago #1069800Hi, erwinb.
I changed some code lines. Please export the class schedule and check again.
7 years ago #1069892This reply has been marked as private.7 years ago #1069986This reply has been marked as private.7 years ago #1070308perfect! thanks, the export feature seems to be working ok now. that will save me a lot of time and trouble.
Is it safe to update the Timetable plugin with the next update? Or will the modification be lost?
thanks in advance!
erwin
7 years ago #1070373Hi,
This issue has not been updated in version 2.0.5.3.
You should wait for the version 2.0.5.4.
