NooTheme Premium WordPress Theme › Forums › JobMonster › Error while importing demo data elementor
- This topic has 11 replies, 3 voices, and was last updated 5 years, 5 months ago by
5 years, 5 months ago #1208010
5 years, 5 months ago #1208030Dear, Please kindly send for me admin account and your site URL via private reply, i will check details to help you.
5 years, 5 months ago #1208041This reply has been marked as private.5 years, 5 months ago #1208054When to wait for the result?
5 years, 5 months ago #1208067Why don't you answer when to expect an answer or a result?
5 years, 5 months ago #1208069Please resolve my issue or I will have to demand a refund.
5 years, 5 months ago #1208074I have had a similar issue with this theme and receiving an error while importing the demo data. I have received no response on my thread. The styling is completely off with the theme and I wouldn't recommend this theme at the moment.
5 years, 5 months ago #1208075Dear, That problem because the demo data of Jobmonster use Elementor old version, I don't understand why it not work with elementor latest version.
To fix your problem: Please use WP Reset plugin to reset your site, then go to admin menu 'Elementor -> Tool -> Version Control' and 'Rollback Version' Elementor to version 2.7.5 then import elementor data demo of Jobmonster.
After import Jobmonster demo data with Elementor, you can update Elementor plugin to latest version.
Best reagrds.
5 years, 5 months ago #1208079Did as you wrote, everything gives an error early. try to go in and see for yourself, I sent access
5 years, 5 months ago #1208082When will you look?
5 years, 5 months ago #1208101It's too bad that you charge money for a non-working product. The problem was never resolved. I will try to solve it myself.
5 years, 5 months ago #1208120Dear, If you have problem when import Jobmonster with Elementor demo data. Please kindly use WP Database Reset plugin to reset your site to new site then update Jobmonster theme on your site to latest version 4.6.6.2 and check import Jobmonster with Elementor demo again.
