NooTheme Premium WordPress Theme › Forums › JobMonster › Error generating and downloading resume
- This topic has 6 replies, 2 voices, and was last updated 6 years, 10 months ago by
6 years, 10 months ago #1074650
I installed the latest version of JobMonster yesterday by hand. With the new version, I also updated woocommerce.
After the update began to present error to generate the impression of the resume.
Clicking on the button does not open the curriculum screen and nothing happens.
It is not a problem with package quantity, because neither the permission message appears, simply no action is generated.
Only the # appears after the link in the top, but does not open the new page.
Please, can you help?
Follow the screen attachment after clicking.
6 years, 10 months ago #1074671
We also checked this issue on our website but it still works fine. Can you give us your website's URL and admin account again? Then we will check on it directly.
6 years, 10 months ago #1074708Hi again,
thanks for answering.I discovered, the problem was in the browser cache. I cleared the browser cache and it worked correctly.
Please, if it exists, could it indicate a prevention for future updates?I thought about using WP super Cache, but I could not configure it correctly to work with JOBMoster. By activating WP Super Cache settings, I had trouble registering jobs or resumes because, at the end of the process, it was not displayed instantly.
Thank you very much in advance
6 years, 10 months ago #1074745This reply has been marked as private.6 years, 10 months ago #1074831
1- We highly recommend you to use WP Total Cache plugin for job website's so you can consider using it.
2- We also got access to your website and checked print button. It still worked fine. Please see the attached image.
Please check it again, then feedback us.
6 years, 10 months ago #1074834Hi,
Thanks for the feedback.
I do not understand, it's just in my browser. I cleaned but did not carry all the information. But that's okay, the client worked.
As for WP Super Cache, do you have some specific configuration that you recommend, or only use the recommendations of the plugin itself?
6 years, 10 months ago #1074926
There is no special configuration in WP Total Cache plugin so you can use it normally.
