NooTheme Premium WordPress Theme › Forums › JobMonster › Employer Not able to view detailed resume
- This topic has 15 replies, 3 voices, and was last updated 5 years ago by
cinef.
5 years, 10 months ago #1157075
Employer with Diamond member is not able to view resume but can post unlimited jobs and all unlimited feature. Why? Ideallyu he should be free to view detailed resumes of every candiate but it says, updgrade your membership. There is no other higher membership available and in job package also, there is no mention of vire resume limit.
Can you please check at back end so that such problem does nto happen to other candidates. I cant test it due to payment requirements.
Please check and help
5 years, 10 months ago #1157551This reply has been marked as private.5 years, 10 months ago #1157668That problem because you set setting 'View and Search Resume Listing' is 'Employers with Paid Package' and can't view resume on your site if don't have pacakge, please go to menu 'Jobmonster -> Settings - Action Control' and change setting 'View and Search Resume Listing' to check again.
5 years, 10 months ago #1157673When I say Diamong package, it mean that it is paid membership only.
This user have paid but not able to see detailed resume. Also i want that only paid members should be able to see detailed resume I have checked "View and Search Resume Listing' to 'Employer with Paid Package'
5 years, 10 months ago #1159009This reply has been marked as private.5 years, 10 months ago #1159047Hi
There is some problem.
In Job Monster Setting-->Action Control --> View Detail Resume == When I select EMplpoyers with paid Package, it does not give me option-->Can view resume.
But when I select Employers only instead of Employers with paid package, it gives me optoin to set -->can view resume
But I want that paid Employer should be able to view detailed resume and FREE employers should only be able to "view & search resume listing" but cannot access detailed resume
Please check this
5 years, 10 months ago #1159049This reply has been marked as private.5 years, 10 months ago #1159859Need to solve it immediately.
Only Employees with paid pacjkage should be able to see detailed resume. Other employees can only'view and list resume"...I need this setting but it is not working
please help
5 years, 10 months ago #1159890This reply has been marked as private.5 years, 10 months ago #1159893every thing is broken now!
I cannot open website
5 years, 10 months ago #1159896This reply has been marked as private.5 years, 10 months ago #1159898I have commented this code it was causing problem as shown in th escreenshot in previous message. Please test and add suitable code accordingly.
5 years, 10 months ago #1159900This reply has been marked as private.5 years, 10 months ago #1159902I hope I will get "show detailed resume" option for all plans I will create so as to enable or disable as per plan.
5 years, 10 months ago #1160655Yes, we're will check and fix it in next update version.
5 years ago #1212050This reply has been marked as private. -
