NooTheme Premium WordPress Theme › Forums › JobMonster › Different issues
- This topic has 8 replies, 2 voices, and was last updated 6 years, 9 months ago by
6 years, 9 months ago #1075487
AnonymousInactiveTopics: 9
Posts: 34Hello,
I need your help in the following issues please :
1- In the candidate profile > profile> "Introduce Yourself" + in the candidate profile>Post a resume> " Professional Summary" + in the employer profile > company profile> "Company Description" + in the employer profile >Post a job> "Job Description" : the font color is white, therefore we can't see what is written (capture 1-2-3-4)
2- In the free job package, I've put the download limit to 0, but the employer is still able to download the attached resume of candidates ( whom did not apply to the job)
3- In the candidate profile > Job Suggest : the expiry date is displayed as "equal to expired date" (capture 5)
4- How to remove the exemple under the address custom field, in the job post and resume post ? (capture 6-7)
5- How does the admin approve jobs submitted ?
6- The "register" button turn to yellow when the mouse is over it, I would like it not to change color. how? (capture 8)
Thanks for the help.
6 years, 9 months ago #1075490
6 years, 9 months ago #1075493
6 years, 9 months ago #1075496
Posts: 34This reply has been marked as private.6 years, 9 months ago #1075535
1. We have got access to your website and checked this issue but it still worked fine. Please see this image: https://prnt.sc/nxtac7
2- Because you configured Who can download the resume: public. That caused this issue. We also changed it in JM Jobmonster > Settings> Resume
3- Our website also got this issue. In this case, we will note it in our list then fix it soon.
4- These texts are contained in our language files so you can use Loco Translate plugin to translate it to another text as your purpose.
5- Please add this Custom CSS segment:
.nav-item-member-profile.register-link a:hover:hover{background color: #f5d006 !important;}
Change for your suitable color.
6 years, 9 months ago #1075540
Posts: 34Hi,
Thanks for your quick reply.
1 - No it's working some places and some places it's not:
- Sign in as a candidate > Member Profile > Introduce Yourself : https://prntscr.com/nxu2rh
- Sign in as a candidate > Post a resume > Professional Summary: https://prntscr.com/nxu618
- When I sign up (not sign in) as en employer, the first time I fill the company profile, the font is white: https://prntscr.com/nxuc4j, and the when I post a job for the first time as en employer, the font is white as well : https://prntscr.com/nxudbs
thanks
6 years, 9 months ago #1075567
We also made a double test on your website but everything works fine. Please make sure that you click to Visual tab before entering your text. Also, please refer to these images.
6 years, 9 months ago #1075578
Posts: 34Hi thank you for your reply.
You understand that it's not possible to ask candidate to click on the visual tab in order for it to work! It should work without clicking on the visual tab like any other field.
Could you please fix ?
6 years, 9 months ago #1075606
Currently, we have used Editor to build the text-box. In addition, we also deactivated Async JavaScript plugin and your editor worked fine. Thus, please check your third-party plugins carefully before using it.
