NooTheme Premium WordPress Theme › Forums › JobMonster › demo data: edit "post" job and "post resume"
- This topic has 11 replies, 2 voices, and was last updated 6 years, 2 months ago by
axelulrich.
6 years, 2 months ago #1082360
demo data: edit "post" job and "post resume" with elementor does not work - see screenshot
6 years, 2 months ago #1082369This reply has been marked as private.6 years, 2 months ago #1082380This reply has been marked as private.6 years, 2 months ago #1082389Hi,
You can send me a screenshot to clarify.
6 years, 2 months ago #1082397edit page "posten" (former "post job")
then "edit with elementor"
screen2
6 years, 2 months ago #1082411Hi,
You mean this page: http://prntscr.com/qehgln
You cannot use Elementor to customize this page. This is a form page template created with only one function -> post a job on your site.
If you want to add or remove or disable fields, you can go to Jobmonster -> Custom Field -> Job tab
It is similar to the "Resume Post" template page.
6 years, 2 months ago #1082418and I cannot get rid of the "POST a job....." and the 1, 2,3 circles in the top?????
6 years, 2 months ago #1082420Hi,
If you want to hide Page title and top steps:
- Hide Page title: You go to Page -> Page settings -> checkbox "Hide Page Title"
- Hide top steps: You can add these lines to custom CSS or style.css of Child Theme:
.jform-steps {
display: none;
6 years, 2 months ago #1082468another question...where do I find the appropriate CSS???
di I have to install the child theme as well? So far I only installed the theme
6 years, 2 months ago #1082484Hi,
You should install the Child Theme.
All customizations you should make on the Child Theme.
After completing the installation, you can place the CSS code to style.css file of Child Theme
6 years, 2 months ago #1082522<i changed the style.css - no difference - what made I wrong??
6 years, 2 months ago #1082523found it - thank you, still love your support
