NooTheme Premium WordPress Theme › Forums › JobMonster › CV – Job Applications -> Function on or of for the transmission of the CV.
- This topic has 6 replies, 3 voices, and was last updated 6 years ago by
digitalewunder.
6 years, 1 month ago #1085088
Request for support:
Is there a possibility that the CVs of the applicants cannot be submitted?
Is it possible to switch this function off or on for the transmission of the CVs. Because some job offers cannot be entered with the correct email addresses. Then jobseekers apply with CVs and we would like to turn this function off and on.
So that the applications are not unread and unseen in the database and are not processed there.
So it would be good if you can only display the job without using this function to send the application.
Thanks for your information,
Günther6 years, 1 month ago #1085099Hi
Thank you for feedback us
I'm sorry but I don't understand
Do you want hide button "Apply for job" ?
or you can more detail description problem , send image problem via: https://prnt.sc/
I will check it for you soon
6 years, 1 month ago #1085162This is exactly the problem - we want to hide this window Apply for this job / on or off.
Is there this possibility?
Thanks Günther6 years, 1 month ago #1085174Hi,
We do not currently have this option, we will update it in the upcoming release
6 years, 1 month ago #1085298Hi Hoannt,
Thank you very much, this is not necessarily necessary - it would also be sufficient if I could inform the applicants as another possibility.
That they don't send the application via the function but send it directly to the company.
Would this information be possible via the template - as soon as the applicant sends his application he gets a message that he should please send the application directly to the company. And not over the function in the template.
Can I set this under messages to the applicant? Thanks Günther6 years, 1 month ago #1085328Hi,
Now update the latest version then go to Jobmonster -> Settings -> Apply Job -> select "None"
6 years ago #1085872super thanks hoannt;-)
I found the new setting under apply job and have now switched it off.
So that no more applications are transferred.
Thanks very much,Günther
