NooTheme Premium WordPress Theme › Forums › Palazzo › Customize property ID ?
- This topic has 44 replies, 3 voices, and was last updated 7 years, 1 month ago by
7 years, 4 months ago #1069008
Hi everyone
Can we customize our ID property when we create an new one ? for our organization it will be better
Tanks lot
Regards
Mike
7 years, 4 months ago #1069057
We are so sorry but currently, we don't support to add property ID as your desired. In this case, you should find a freelancer developer to help.
7 years, 4 months ago #1069117Hi I can't load correctly your theme demo on my website
http://www.traspaso-espana.com
It's seems that's no work good..
Can you help me plz ?
regards
Mike
7 years, 4 months ago #1069118Maintenance mode I can give you admin dashbord if you need..
Mike
7 years, 4 months ago #1069161
Posts: 3295Hi again, Mike
Sure, please give us your admin account and FTP account privately via checking Set as private reply checkbox. We will check your issue as soon as possible.
7 years, 4 months ago #1069207This reply has been marked as private.7 years, 4 months ago #1069218This reply has been marked as private.7 years, 4 months ago #1069272
We have got access to your website then took a look. They found out you didn't have a Footer Block on the homepage.
After that, we helped you to create a Footer Block then shown it to Homepage. It worked fine.
Please your website again, then feedback us.
7 years, 4 months ago #1069284This reply has been marked as private.7 years, 4 months ago #1069294Hi again it's fine I fix the pb about compare and submit
Have a nice day
Mike
7 years, 4 months ago #1069341
You can go to Settings > Reading > Homepage to choose a home page on your website. In addition, don't hesitate to ask us if you have any questions.
7 years, 4 months ago #1069362This reply has been marked as private.7 years, 4 months ago #1069375This reply has been marked as private.7 years, 4 months ago #1069402Last question ...where can I customize schedule tour contact on single property? I didn't find anywhere
Mike
7 years, 4 months ago #1069433
We have got access to your website then helped you to fix all issues.
Please check again, then feedback us.
7 years, 4 months ago #1069452Hi everyone
Thank you so much and all work good on the website ...I give you 5 stars ;))
And this theme is very good and easy to use it
Take care
Mike
7 years, 4 months ago #1069474
You can go to this our product link then give us a 5-star rating: https://themeforest.net/item/palazzo-real-estate-wordpress-theme/20955621
It is motivation and confidence for us to serve you even better.
Thanks so much.
7 years, 3 months ago #1072337This reply has been marked as private.7 years, 3 months ago #1072422
Posts: 3295This reply has been marked as private.7 years, 3 months ago #1072446This reply has been marked as private.7 years, 2 months ago #1072521This reply has been marked as private.7 years, 2 months ago #1072532Hi again.
We have checked and fixed the issue on your site.
7 years, 2 months ago #1072537This reply has been marked as private.7 years, 2 months ago #1072558This reply has been marked as private.7 years, 2 months ago #1072588
