NooTheme Premium WordPress Theme › Forums › Visionary › Customize blog entries
- This topic has 10 replies, 3 voices, and was last updated 7 years ago by
7 years, 1 month ago #1068580
Hello, please, could you help me? Where can I set up the start of the blog? The shortcuts appear by default. I do not want so many links to appear because the public can get confused. For example, when entering my blog, which is clicking on "#somoslargavista" from the main menu, there are several links under the title, I do not know why they appear, I have not put them, I attached image of this. Also in the blog list format, links appear that should not be on the right side. The author's name appears and you can click, which I do not want to be. The "tags" either, since I'm not using them and they are blank, so it does not make sense that they are. On the left, another link that says #somoslargavista ... that should not be linked because it leads to another blog, with another format that is not what I want. I hope you can help me, in general this template is very good!
7 years, 1 month ago #1068611Hi again.
As I see, you are using the shortcode to build the blog page and you also set up the post page is a blog at Settings/ Reading.
We have removed the blog page selected on the reading config, it will help you remove the blog breadcrumb link.
7 years, 1 month ago #1068895
Posts: 3295This reply has been marked as private.7 years ago #1069023This reply has been marked as private.7 years ago #1069024Hello again. In the previous post it was not clear what I need to solve. I just do not want these links to appear in every article of the blog. Attached image. These are:
- "by JaMCCGJPAz"
- Date: February 13, 2019.
- Tags:In addition, the link to the category appears. It is not necessary to appear, because when you click, it goes to another page with different content but with another design that we do not need.
Can you delete the links mentioned and make the category not appear with a link to another page, in each article?
Or tell me how to do it please
I will be careful. Thank you
7 years ago #1069026I also need to know how I can do to link each image and title of this section (attached image) to some personalized links. At this time the title is linked to the portfolio, but I need you to go to some blog news 🙁 I'll be careful.
7 years ago #1069072Hi again.
We have help you removed the link on the blog list page.
Please check it again. We have changed the source code at this file /wp-content/plugins/noo-visionary-core/admin/vc_extension/shortcodes/noo-blog-list.php
With the next issue, please give us the image again. You should upload the image to another source and give us the link. Our maximum file size allowed is 1048 KB.
7 years ago #1069097Hello, I realized that in my blog session the user and the date still appear but are no longer linked. It would be ideal to definitely not appear, only if possible.
When I enter an entrance (link attached) http://largavista.cl/index.php/2019/02/13/solsticio-cerveza-sol/
Among the links that appear in the header, the linked category still appears. Could you help eliminate the category? It would be ideal that instead of the category, here appears the link of the page of the blog, so that the users who are inside an article can return to the blog easily. I do not need the category anywhere, since it has the same entries entries from my main blog but with another layout. Attached image. Be careful. Thank you7 years ago #1069198
Because you have configured in Settings > Permalinks: Post name (you included date and year here). In this case, we also helped you to remove it to get rid of this issue.
Please check again, then feedback us.
7 years ago #1069766Hello, could you help me? It is urgent. I do not know what happened, but all the links in the portfolio are broken. In the link appears something like "trashed portfolios" that I had not seen. I find it very strange because a week ago this was working well and I have not moved anything. It is urgent please. I will be attentive. regards
http://largavista.cl/portfolio__trashed/brujas-de-salamanca/
7 years ago #1069949Hi again.
We have checked and found the issue from the portfolio page. You have removed the portfolio page on the page management, but you do not remove the portfolio page selected on the customizer/ portfolio setting.
We have fixed that issue.
