NooTheme Premium WordPress Theme › Forums › JobMonster › CSS problem in Job Overview
- This topic has 12 replies, 2 voices, and was last updated 6 years, 3 months ago by
6 years, 5 months ago #1080230
I don't know how to make better with what I have here. You'll see the overlap of informations in the description. Can you fix that ?
https://leaderdeprojets.com/empleos/asistente-de-ventas-automotriz/
And I would like to chnage all english words in the template that have not been done. How can I do it, what do you recommand?
For exemple in this page I have the word Overview Job that show be in spanish "Descripción general del trabajo"
6 years, 5 months ago #10802426 years, 5 months ago #1080282This reply has been marked as private.6 years, 5 months ago #1080298Hi,
You can add these lines to custom CSS:.job-details.style2 .job-custom-fields ul li {
max-height: none;
6 years, 4 months ago #1081531This reply has been marked as private.6 years, 4 months ago #1081534This reply has been marked as private.6 years, 4 months ago #1081535This reply has been marked as private.6 years, 4 months ago #1081543This reply has been marked as private.6 years, 4 months ago #1081642This reply has been marked as private.6 years, 4 months ago #1081655Hi,
I install the Loco Translate plugin and translate some the above text.
You can use it to translate the text that you want.
6 years, 4 months ago #1081691Thank you, it works for most of it.
I just miss some of it that I could'nt find with Loco Translation plugin, there are :
1- Full Address from the profile form (see snapshoot)
2- Job Expired from a Job Sheet
6 years, 4 months ago #1081694And also the word Search (see snapshoot)
6 years, 3 months ago #1081709Hi,
- Full Address: You go to Jobmonster -> Custom Field -> Employer tab -> http://prntscr.com/q22udy
- Job Expired, Search: We will update in the next version.
