NooTheme Premium WordPress Theme › Forums › JobMonster › Copy Job: For Employer or for owner site
- This topic has 15 replies, 2 voices, and was last updated 7 years, 2 months ago by
7 years, 2 months ago #1066610
is there in Job Monster the possibility to copy a job? Both for me as the owner of the site and for an employer? I have many of the same vacancies but I have a different location.
Please let me know! thanks in advance
7 years, 2 months ago #1066664
Yes, definitely. You can copy the jobs by clicking a clone button when you access your website by employer account.
If you access via admin account you can duplicate job directly in Dashboard.
Please check, then lets us know.
7 years, 2 months ago #1066668Hi Tracy,
Can you show me print screens of the buttons? I don't see it.
Thanks in advance!
7 years, 2 months ago #1066677
You can see the attached image for more details.
In addition, if you duplicate jobs in the backend, please use this plugin to help: https://wordpress.org/plugins/duplicate-post/
7 years, 2 months ago #1066682As an employer I only have the options to edit or delete. How can I add other options?
7 years, 2 months ago #1066691Also, I installed the plugin Duplicate Post and it does show on Pages but not on Jobs. How can I add it?
7 years, 2 months ago #1066732
Please give us your website's URL and admin account privately via checking Set as private reply checkbox. We will help you to check this issue.
7 years, 2 months ago #1066766This reply has been marked as private.7 years, 2 months ago #1066778
We have got access to your website then checked your issue.
You are using the older version of Jobmonster theme so you should update the newest version of theme(4.5.2.0) to fix all issues.
NOTE: BACKUP ALL CUSTOMIzATION FILES AND LANGUAGE FILES BEFORE UPDATING.
7 years, 2 months ago #1066785Do I need a plugin? I get an error that says its forbidden
7 years, 2 months ago #1066787Hello, my update is "forbidden". I got the envato toolkit installed (including API key and all) but still it doesn't work. Hope you can help me today!
7 years, 2 months ago #1066790This also didn't work:
If you use Jetpack plugin. Please deactivate that plugin and update theme. After that, you can active again.
If not, Please go to Jobmonster/Quick Setup and click SAVE CHANGES button and try to update theme again
7 years, 2 months ago #1066796okay, got the new update. But still no option to copy.
7 years, 2 months ago #1066835
We also accessed your website then we still found the clone job button on the front page. Also, see the attached image.
In the backend, we also install Duplicate Page plugin and it worked fine.
Please check again, then feedback us.
7 years, 2 months ago #1066857You make my day!!
7 years, 2 months ago #1066907
