NooTheme Premium WordPress Theme › Forums › LandMark › content on WPBakery shortcode is not translated in advanced mode
- This topic has 8 replies, 2 voices, and was last updated 3 years, 4 months ago by
3 years, 4 months ago #1219550
1.Why does the content of pages not appear in advanced mode?
Everything inside the shortcode is not translated in advanced mode. https://ibb.co/1T9zpL3
AND When searching for the word in string-translation Page on wpml plugin, the content of the variables shows "symbols" such as the image. https://ibb.co/QKsXQKL
I use wpml .
2. The search engine on the home page does not work in the second language “Arabic”, I mean that the search options do not work “drop-down lists”, only the search button is what works. https://ibb.co/yVRVFDq
link: https://feelhomeqatar.com/ar/
thanks .
3 years, 4 months ago #1219560Hi.
The string in the shortcode is the encoding of the WPBakery. You can’t translate that string, it will doesn’t work when you change the code.
For the dropdown list on the search form, please give us your site admin account. We will help you debug that issue.
3 years, 4 months ago #1219567This reply has been marked as private.3 years, 4 months ago #1219568Attached is a picture of another site where I use wpml and WPBakery, and as you can see in the picture, the speech appears normally, whether Arabic and English, and does not turn into symbols
3 years, 4 months ago #1219570On another site, as in the picture, I can translate all the page content in the advanced mode, but with your theme, only the page title and keywords appear, and the rest of the page content does not appear in the wpml advanced mode
3 years, 4 months ago #1219585Is the problem clear now?
I have attached the admin login data here to the above. Is this safe? Because I see that all support tickets are available for everyone to see.3 years, 4 months ago #1219593Hi again.
I have set it private for your reply, but maybe you have changed the password. Please give us your site admin account again. Don't forget to set "Private reply" for your site info. https://prnt.sc/iN0mjlSLNtHf
For the symbol on the shortcode, that is the shortcode config. Please give us access to your website. We will help you check it.
3 years, 4 months ago #1219605This reply has been marked as private.3 years, 4 months ago #1219608Hi.
I have checked your website and the source code, you can't translate the shortcode via the string translate option of WPML. For some shortcodes, it doesn't show the shortcode content as the string to translate. It will decode the config.
Please go to edit the page and edit the shortcode to translate the shortcode config. https://prnt.sc/DuIFscm_QPDs
