NooTheme Premium WordPress Theme › Forums › JobMonster › Companies list is empty ! and mailer gives an error !
- This topic has 14 replies, 2 voices, and was last updated 6 years, 11 months ago by
7 years ago #1070964
Hi ,
I've updated my theme to the latest version and I'm facing these issues :
- the companies list in the backend is empty! even though I have companies added, please follow this link to add a job and from Posted by ( Employer - Company ) list
https://libyajobs.ly/wp-admin/post-new.php?post_type=noo_job
- The SMTP mail plugin shows error when I try to test it
SMTP ERROR: Failed to connect to server: Connection timed out (110)SMTP connect() failed.
is that a setting in the server or something in wordpress ?!
7 years ago #1070965This reply has been marked as private.6 years, 12 months ago #1070980
1- Currently, when you enter a company name in Company option, it will show a suggestion list as this image: https://prnt.sc/n1q0vl
You can check this on your site.
2- You should contact your hosting provider to solve this issue.
6 years, 12 months ago #1070995Thank you for your kind reply
another question - may be a naive question! - where can I make employers registration approved first by admin?
not like job seekers which don't need approval from admin.
6 years, 12 months ago #1071034
You can use this plugin to make it:https://wordpress.org/plugins/wp-approve-user/
6 years, 12 months ago #1071071This reply has been marked as private.6 years, 12 months ago #1071160This reply has been marked as private.6 years, 12 months ago #1071200
1- Yes, this plugin doesn't allow you to approve a specific user. The user's role is depended on the registration action.
2- Did your site have a Fatal Error issue? Please give us your admin account again because the old one is wrong.
3- For translating, you can go to Jm Jobmonster > Custom Fields> Then edit these fields directly. Also, see this image https://prnt.sc/n3eum1
Please check it again, then feedback us.
6 years, 12 months ago #1071240- For translating, you can go to Jm Jobmonster > Custom Fields> Then edit these fields directly. Also, see this image https://prnt.sc/n3eum1
this will change the text on both sites (English/Arabic ) it's not a translation!
6 years, 11 months ago #1071289
Can you provide us with your admin account again? We will get access to your website then check it directly.
6 years, 11 months ago #1071425This reply has been marked as private.6 years, 11 months ago #1071483
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1071541This reply has been marked as private.6 years, 11 months ago #1071543This reply has been marked as private.6 years, 11 months ago #1071599
Posts: 3295This reply has been marked as private. - the companies list in the backend is empty! even though I have companies added, please follow this link to add a job and from Posted by ( Employer - Company ) list
