NooTheme Premium WordPress Theme › Forums › Palazzo › Como alterar cor da linha e textos do rodapé 4
- This topic has 3 replies, 2 voices, and was last updated 7 years, 1 month ago by
7 years, 1 month ago #1068032
Good night.
I would like information about the update, if everything is okay to happen tomorrow, there is already a month that I bought the theme and I could not use it yet.
I would also like to know if it exists and if it exists, where I can change the colors of the text and the lines of these contact features that have in footer 4. At the moment I can only change the color of the background, the attached photo follows.
I also wanted to know if it is possible to use the contact system of CITIZONE in the home that I am leaving, at the moment it is on the following demonstration page: http://wp.nootheme.com/palazzo/property-landing-v1/
And I tried to put the page that I am installing on my site but it was unconfigured.
Also help me on how to make the logo appear in the floating menu when the person rolls the mouse down, I've seen in several sites that ask for support here in the forum, but mine does not appear.
7 years, 1 month ago #1068108
Thanks for contacting us
1- We also got access to your website then tried to found the footer section as your image but we don't see that. In addition, we see the footer section on your homepage, the text color changed, see this image: https://prnt.sc/mf10r5
Please check it, then give us your link directly if you still need to help.
2- "I also wanted to know if it is possible to use the contact system of CITIZONE in the home " we don't understand your question clearly
3- https://ziag.com.br/site/property-landing-v1/
This page also exists on your website, please check again.
4- Because you have used Header 1 to build your header. Therefore, this header doesn't have a sticky logo.
You can try using Header 3,4,5 to make a sticky logo.
7 years, 1 month ago #1068150Good night.
The explanation of the fixed logo I understood perfectly, now we go to what I did not understand and to what was not answered.
1- I asked about the update that was scheduled for yesterday 01/31/2018 in the theme, where I could put the map without having to use a credit card, (remembering that I can not add real estate in the site because the field of address does not appear on the property dispatch page with this map problem).
2 - I'm talking about exactly this form that is on this page (https://ziag.com.br/site/property-landing-v1/) plus I'm using another layout, which is in (https: // ziag. com / site /), my question is, if I could use it on that page I'm using because I put it the most got misconfigured.
3- The footer section I am referring to is Footer 4, but what I wanted to ask myself is is if there is a way to change the color of the items, the background give to change the color plus the elements do not. It's element (Noo Simple Information) I put it in the layout I'm using, but it only lends if I put it in a color, because the text and the lines are white, the only color I want to know where I can edit , the color of the texts and the lines, because the background I want it to stay white like the rest of the site.
7 years, 1 month ago #1068288
We are really sorry for late response because we got a long holiday for the lunar new year so we cannot help you during that time.
For your question:
1,2 Please check your website again because we cannot get access to it. Also, see this image for more details: https://prnt.sc/mjcwgl
3- Currently, we don't have an option to change the color separately but we can help you by adding a Custom CSS segment. Please tell us what section do you want to change exactly? We will help you to check soon.
