NooTheme Premium WordPress Theme › Forums › JobMonster › color of the map icons & job alert not sending
- This topic has 9 replies, 2 voices, and was last updated 6 years, 9 months ago by
6 years, 10 months ago #1074858
1. Where can I change the css code for the yellow pointers & buttons on the map view?
2. I saw another customer who had problems with the job alerts not being sent. Has this been solved yet?
Thank you!
6 years, 10 months ago #1074930
1- Which map section do you want to focus? Can you give us an image of it?
In addition, you should give us your website's URL and admin account privately then we will check it directly.
2- Yes, we fixed it on the latest version of Jobmonster theme. Please update it then check this issue again.
6 years, 10 months ago #1075002This reply has been marked as private.6 years, 9 months ago #1075102
1- We got access to your link but we don't see the map section in here. Please see this image: https://prnt.sc/nuozg2
2- When updating the newest version, the language will be lost so there are 2 ways to keep your language:
- Copy your language file to {root}/wp-content//languages - this is the language of WordPress so it will be kept when you update Jobmonster newest version.
- Use the Child Theme. We also attached a blank child theme in our package so you can install it then learn about how to use it. It is very convenient for you.
6 years, 9 months ago #1075156This reply has been marked as private.6 years, 9 months ago #1075226
Posts: 3295This reply has been marked as private.6 years, 9 months ago #1075232This reply has been marked as private.6 years, 9 months ago #1075295
Posts: 3295This reply has been marked as private.6 years, 9 months ago #1075306This reply has been marked as private.6 years, 9 months ago #1075316
We have used the icon image to build these points and buttons so you can go to {root}\wp-content\themes\noo-jobmonster\assets\images then replace your images here. Also, see the attached image.
